snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Thanks joe,so I am hoping for the full 16.9 on max 16msm and cold air,was told should be around 275 hp.Orange gets 16-17 psi. All stock bov and map sensors. All we did was flash and clutch it.
Blue wd with pt gets 15 psi
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I’m thinking I might put the max 16 on Blue sometime but the pt flash Is very nice in itselfThanks joe,so I am hoping for the full 16.9 on max 16msm and cold air,was told should be around 275 hp.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Ya,i had a very difficult time deciding between the two,PT or max 16,as I have just one flash,i almost did the PT because of 87 octane can be run in it in a pinch,but the last tune I ran was always 93 or 91,and here in maine,fuel is ok most of the time,and I wanted the knock light,and PSI in my gauges,so back to TD tune,i ran the TD 4 stage in my 13 cat.I’m thinking I might put the max 16 on Blue sometime but the pt flash Is very nice in itself
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
What kind of mileage are you getting with PT SM?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
very close to stock mileage , a bit better if your not on it the whole time, doesn't happen thoughWhat kind of mileage are you getting with PT SM?
mbarclay
You guys are getting the knock light and psi in the gauges with the td guage reflash?
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yes, really nice to see how much boost at different rpms and throttle positions, and knowing that you will see the knock light if you got some bad fuel etc.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
- 2017 Yamaha Sidewinder
2014 ZR9000 turbo
- Gatineau, Quebec, Canada
- turbodynamicscanada
- YOUTUBE
- TurboDynamicscanada
Well if in fact you decide you need a bit more, I think you shall find that an update flash is very cheap compared to the initial flash. I updated from ecotrail to max Spool 16 for $150 - 160ish. Smiled from ear to ear afterwards.
Probably not much difference for you though whereas you already have the Powertrail flash.
Cool, being able to see your boost psi and knowing that that knock light is there huh?
Max spool 16sm is NIGHT and DAY difference even with powertrail SM.
Turbo Dynamics
- Jun 16, 2016
- Gatineau
2014 ZR9000 turbo
- YOUTUBE
Max spool 16 is 260HP without anything. With BOV and 3 bar it's higher than 260HP, it makes more boost.Was you able to see the PSI on your TD PT,was it at 15lbs,or less? Do both sleds have Newer BOV td sells and I am sure hurricane does too.I am told most stock BOV bleed down after 15.5 lbs and now I have max 16 TD,and map3 sensor,but have been waiting to run it,to see if I need the newer BOV or not.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yep sure does make some good boost numbers. 2 of us with same Max Spool 16 ( 3 bar & BOV), are seeing up to 17.5
Very impressive power.
Can you use the stock muffler with Max spool 16 ?
Yes, see TD's above post from 10:36pmCan you use the stock muffler with Max spool 16 ?
- 17K
- 7K
