KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
@KnappAttack cat purple has been working good for me the past 2 seasons, not perfect for every riding and clutching setup but has worked damn well for me the past 3500 miles. Great mix for backshift coming in and out of corners hard.
Sent you a PM.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Just a little update.
We are now testing an updated stock muffler 270 flash. After some testing it seems there is more to be had.
Heading out in the morning to test. I will have a real world review when I get back.
WinterWolf
- Mar 25, 2017
- Connecticut
Joe, what do you mean by updated?? Updated how?
KnappAttack
- Feb 19, 2004
- Welch MN
I'm guessing they went to the 3 bar map sensor tune with BOV. He said earlier they were only getting 16 lbs boost so pretty sure it was leaking off the stock BOV.
WinterWolf
- Mar 25, 2017
- Connecticut
That’s what I was thinking too...but wasn’t sure. Thanks.
Mototown
I bought both BOV & 3 bar map sensor, only put the BoV in , rpm went up 200 rpm and even had some deto flash for the first time . So just the BoV is a improvement.
geez150
Will all 998t benefit from these two upgrades or is it just more so on the 270 and up tunes?
bleedyamaha
- Sep 28, 2013
- Northern Iowa
I read somewhere on here the ecu won’t recognize the 3 bar without a tune. So don’t do it unless you are doing a tune
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Your tune has to be set to recognize the 3 bar sensor. You will have a boost sensor error otherwise.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
3bar only needed for STOCK MUFFLER TUNE as per this thread.
Not needed for us guys with older jukebox with 2.5" mufflers.
Dan
Dan
actionjack
- Apr 9, 2005
I think I understood the response differently than that. 3 bar gives ECU/tunes more accurate boost reading. Higher boost tunes benefit even more from 3 bar. Probably wrong.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Thats what hurricane told me only stock muffler3bar only needed for STOCK MUFFLER TUNE as per this thread.
Dan
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Is anyone running the 270 flash on a stock muffler? Is it pig rich?
WinterWolf
- Mar 25, 2017
- Connecticut
There is a 270 SM Flash, that’s meant/designed to run with the Stock muffler. Are you referring to a normal 270 flash, (that’s not a SM Flash), and running that with a Stock muffler?
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Yes...There is a 270 SM Flash, that’s meant/designed to run with the Stock muffler. Are you referring to a normal 270 flash, (that’s not a SM Flash), and running that with a Stock muffler?
