SledFreak
- Feb 7, 2005
- Ontario. Canada
Srxspec said:I'll let you know in the next week or so. Just got a batch of Tied setups in and will be testing it out on a XTX soon!
Hey Allen, Any more testing on this?
POWERHAULIC
SMOOTH is the best word.
After 6 WOT passes on the lake both clutches are very cool to the touch.
So far a great improvement
SledFreak
- Feb 7, 2005
- Ontario. Canada
Any more top end, acceleration?
POWERHAULIC
I still dont have the RPMs high enough only spinning 10200 max. Took 1gm out and added 20# finish w/no change.
But still accelerates better and has more topend pull than best setup before.
Time to try more spring in the converter.
vsmpowered
- Feb 16, 2009
- Rochester , NY
- Nytro xtx Viper ltx se
tedgoesfast
we have spent alot of dialing time with one on a sdi ski poo good results but you will have your hair pulled getting it set up only ploblem is getting enough side pressure to let it run coll
Check out the thread on Ulmar's forum. I have posted all my results there on my MTX 144 I am not dialed in yet but its decent and Im starting to get the feel for how it will perform. It shifts so fast I have not even knowticed it back shifting. The only prob I see is they dont Mfg any helix's that are really right for the 4-strokes so you have to get the one with the kit and from there you will be dealing with custom cut. But Team has ben really good about standing behind the kit they sold me and have ben sending me stuff to try at no cost. I am getting it to the point now that I will be able to order a custom helix and be fairly sure it will work good. Once I get it spot on I will post the results but there are not many running a 144x2.5 in the deep stuff at sea level so my results will be different than most. There 0-3000 trail set up did work great for the trails though but going from my mountain set up it is not a got comparison.
- 46K
