FormulaPro
Thanks Black... looks like I have to do a little Playboy.com surfing... man, she is hot!!
Black 1000
Absolutely
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
- Apr 17, 2003
- Menno, SD
- Menno, SD
Updated again with final price with the proper screws to attach the windage plates to the secondary.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Tork said:I ran most of Goebic on 6 inches of fresh snow twice last week, all of it over 60 MPH ans some of it over 100.
With the plates on, clutches (secondary) were warm but by no means hot.
What blew my mind is how hot the chain case gets tho.
I use the same synthetic engine oil in the chain case as I use in the engine, it is much thinner than the recommended gear oil. I use a 100 cc more than recommended because of the thin density of engine oil. I haven't had any issues running it like this on my turbo sled. BTW engine oil will take the heat much better than gear oil if you get any heat build up.
Is this heat issue only related to the models having magnesium chain cases? 2006 model year sleds?
