hygear
TY Advertiser
The Single Shot Solution!
Hygear Suspension has developed a coil over solution for the Yamaha Apex and Vector chassis using the single shot rear suspension. The undersized stock 1.5 float shock is replaced with a much larger 2.0 Fox Coil platform that is built using Hygear Suspension’s custom Fox H1 build specifications. The shock features include large capacity damping control that is more suitable for single rear shock suspension applications. It offers spring preload and low-speed compression adjustment that provides reliable service for trail conditions. The shock kit comes with additional accessories needed for mounting that also helps improve suspension movement. Testing has proven there is a major difference in ride performance that feels much more comparable to the original Yamaha Mono shock applications. The suspension now utilizes full travel to help smooth out the small to medium size high-speed repetitive stutter bumps with improved bottoming resistance for larger moguls. - $949.99
Gets yours today and order from the link below:
https://www.hygearsuspension.com/products/fox-hygear-h1-apex-single-shot-2-0-ra-coil-over-rear-kit
Do you have additional questions, feel free to call us!
607-533-7434
607-533-7434
20/80
Thank you, but it would be nice not having to remortgage the house to buy one.The Single Shot Solution!
607-533-7434
CaptCaper
- Jan 1, 2007
- Northern N.H.
Why is your shock twice as much as Elka's? some details why?
furg69
wow I have bought used sleds cheaper then that lol
607-533-7434
Way to much money for me. I would be interested in the 500.00 range.
