drunkenrich
I bought this for my 2009 yamaha nytro a few years ago and i have no clue what it replaces...:i just looked at all my fuses on the sled, cant find one that matches.
natedawgedog
they are replacements for the relays in the front of your sled, mainly for the fuel pump relay.
http://ty4stroke.com/threads/fault-codes-relay-fuse-location-wire-diagram-diagnostics.83992/
drunkenrich
Thank you. Do
You guys recommend buying any others to keep in my back pack for emergencies?
natedawgedog
Thank you. Do
I believe you can change all but the load control relay out with the new solid state relays. its been a few years since I've changed out mine, I don't keep a spare around anymore. an extra wouldn't hurt I guess though. they don't weigh much and take up very little space, but I haven't had a problem with my fuel pump relay since I changed them out
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
You can change all of them except the headlight relay which has a different configuration.
sportster64
Will that same relay work for the starter relay, or is it a different solid state relay for the starter relay, I thought the red relay would only replace the fuel pump relay, didn't know I could put a solid state one in for the starter relay.
Dr. FeeLGooD
3 are the same.
