Three bond 1194 for oil case seal?
Will this create difficulty in the future when you go to take it off? Or can it be pryed off easily..
MS
1194 will come apart fine. You'll just have to scrape it off. But like cannondale said. If it's not leaking it's not coming off
Tonight I got into fixing my oil leak.
Once I removed the oil tank i cleaned up everything and checked the faces. The Chain case side of the tank is not flat, and that is right where the leak was.
I will be calling dealer for a new tank and chain case cover.
If you have a leak make sure to check the mating faces or it could leak again!
