shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Here's another pic of bolt. Yes you have to remove sleeve to use puller.
Torque clutch at 88 lbs then remove bolt install sleeve and bolt and torque to 45 lbs. It does take a thin wall socket to fit. I have both snap-on and craftsman and the both fit.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I wonder if the older covers are slightly different. I only have about 1 turn of adjustability before it bottoms out.
- Apr 14, 2003
- Hessel, Michigan
Can you take a pic?
I mentioned this to Lonn and he said the old covers can be updated.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I think I will call him. I already pressed the updated bushing back out of my older cover. Maybe I will just get the new cover and sell my older one.
- Apr 14, 2003
- Hessel, Michigan
Yeah, hard to say what is going on there.
Like many people are saying, the new 911 cover works awesome
viperxtxx
- Dec 21, 2015
- Regina
- 2015 Viper XTX
couldnt decide which clutch kit to get. Seem like a good kit.
- Apr 14, 2003
- Hessel, Michigan
Lonn at Thunder Products really sells a nice kit.... Plus the support from Lonn is outstanding! He's a great guy and will answer any question you have
4StrokeAddict
- Apr 13, 2015
- Michigan
- 2015 SR Viper LTX SE
Yep, he called me yesterday making sure I was all set with my kit. I originally called him inquiring and was ready to pull the trigger. That forced me to decide turbo or no turbo. I told my dealer who was using another kit about the big venom kit and they were immediately interested. My dealer is now giving a clutch kit choice when doing turbos and they will be testing them on their machines this winter. Lonn knew this whole transaction and felt it was important to check in with me to make sure everything went smoothly. Very impressed!Lonn at Thunder Products really sells a nice kit.... Plus the support from Lonn is outstanding! He's a great guy and will answer any question you have![]()
YAMMAROB
- Feb 11, 2013
- Dyer, IN
- 2014 XTX Viper Hurricane Turbo,
2015 MTX Viper
Sons: 2009 Phazer Suprecharged RTX Streched to 153
NICE
fiddlersgreen
- Feb 19, 2009
- Newfoundland...The Rock
- Viper xtx le
Just installed the BOP soft start spring with the big venom kit.
I now have buttery smooth engagement at 2700-2750. With the stock spring it was around 300-3100 and a little more jerky.
we need snow now for further testing on pull!!!!!!!!
4StrokeAddict
- Apr 13, 2015
- Michigan
Can't wait to see your results! Does that BOP spring work with turbos?Just installed the BOP soft start spring with the big venom kit.
stingray719
I have BOP on both my turbos. As far as I can tell same results as GWG
Studroes144
- Oct 30, 2013
One thing I've learned over the last couple years between my viper and a buddies 7000 is that engagement rpm doesn't always determine a difference between smooth and not smooth engagement. My turbo viper engages at 2800 and is very smooth, I can creep on a concrete garage floor at 1 mph and not spin the track that has a bunch of studs, my buddies 7000 engages at 3700 and is as smooth or smoother than my viper at 2800. It also has a bunch of studs and I can start and stop in forward and reverse and creep at 1 mph on my concrete garage floor and never feel like it's gonna spin the track. The higher engagement does affect it a bit more in loose snow on a hard launch, but as far as initial engagement and being smooth I think a good clutch/belt combo is the key more so than actual engagement rpm.
So now ur saying u need the BOP soft spring with the Big Venom kit to get low engagement ?? I thought with just the venom kit it engages at 27-28 , the more u read on here the more confusing it is lol
shagman
Vendor
- Feb 18, 2014
No it's not required. BOP spring is not part of this kit.So now ur saying u need the BOP soft spring with the Big Venom kit to get low engagement ?? I thought with just the venom kit it engages at 27-28 , the more u read on here the more confusing it is lol
