fiddlersgreen
- Feb 19, 2009
- Newfoundland...The Rock
- Viper xtx le
the big venom kit with the stock spring will give you a lower and smoother engagement then the stock setup but from my experience the BOP spring with the big venom kit is even more smooth and less jerky.So now ur saying u need the BOP soft spring with the Big Venom kit to get low engagement ?? I thought with just the venom kit it engages at 27-28 , the more u read on here the more confusing it is lol
As I said before we need snow to check it out for sure.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Just keep in mind the BOP spring is stiffer than the stock spring (total force) and will probably require some tuning to get the rpms back in the right spot.the big venom kit with the stock spring will give you a lower and smoother engagement then the stock setup but from my experience the BOP spring with the big venom kit is even more smooth and less jerky.
fiddlersgreen
- Feb 19, 2009
- Viper xtx le
Ok thanks for the heads up.
Will try with the BOP spring first and if the rpms are ok I'll leave it. If not I'll put the stock back in and check that.
would the stiffer BOP spring effect the pull of the sled in a drastic way with the big venom kit.
shagman
Vendor
- Feb 18, 2014
It's going to effect the amount of weight you put in the weights. You might hit the rev limiter with that spring. To adjust you will have to add weight to bring your rpms down. I run a stiffer spring with my turbo but also run a different helix when I do. The idea with this kit was low smooth engagement and use as many stock parts as possible to keep cost down but have better performance and mileage. Clutching is always a compromise give and take so there are different things that can be done. It's just hard to test everything. Keep us posted and we will help you. We have no snow here but are going to Colorado, leaving Saturday for a week to ride. I'll try to check in when we have cell signal or if.Ok thanks for the heads up.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I thought nos pro said the kit brings engagement rpm down to 2600, still have my kit in the box, don't want to tune on the trail, waiting for snow around the house.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I ordered my kit off the website before talking to Lonn, just wondering if the preloaded weight's are setup for a stock viper,all I have is ulmers intake and can, guess I am kinda worried that I'll be hitting the rev limiter.
shagman
Vendor
- Feb 18, 2014
If Lonn set them up for you it will be good.I ordered my kit off the website before talking to Lonn, just wondering if the preloaded weight's are setup for a stock viper,all I have is ulmers intake and can, guess I am kinda worried that I'll be hitting the rev limiter.
JustBoostIt
Vendor
- Apr 25, 2007
- Lloydminster, AB, Canada
- Evo turbo M7000 162 custom
Nos Pro, does Lonn have anything for the 7000 guys? I've had some inquiries from guys I'm doing flashes for.
- Apr 14, 2003
- Hessel, Michigan
Yes, testing is in the works right now. PM'ed you
randh
- Dec 17, 2015
- Carol Stream,Il
- 2014 arctic cat zr 7000 sno pro limited
Nos pro I would like info on kit for the 7000 also Thanks
jakehayamaha
Thunder Products has a clutch kit now just for the Vipers! The kit is called the Big Venom Viper kit and uses the Heavy Hitter weights that have been around for years which I have used in the RX-1's, Apex and Nytro myself....now my Viper. Lot of testing went into this kit to improve the whole range of performance for the guy who wants good fuel mileage.... to the guy who wants to rail the trail...to the guy going off-trail thru the trees.
These Heavy Hitter weights are balanced out perfectly and the whole kit will come with Heavy Hitter weights with all the hardware for adjustments after more miles and break-in.... (if and when needed), Thunder Products glide washer kit to protect the primary clutch cover (keeps the primary spring from twisting and breaking) and a new secondary spring that not only eliminates the coil bind problem but also makes this kit have very low engagement, pull hard from bottom end to top end and the best part is getting much better fuel economy. The kit complete is $295
Here is an installation video to show you how easy the install is.
Great video! Plan to install with 911 cover tomorrow. For the new secondary spring, which holes are best for trail riding? And are different holes better for more bottom end or off trail riding? Any info appreciated. Thanks
shagman
Vendor
- Feb 18, 2014
Run 6-1 for trail and 6-2 or 6-3 for off trail.
jakehayamaha
Ok thanks. So 6-2 or 6-3 is better on bottom end but loses some on top? What about for like 1/8 mile drags? Or does it not make a whole lot of difference?
shagman
Vendor
- Feb 18, 2014
Depends on surface. Ice 6-3. Snow 6-2.
jakehayamaha
What about all the other holes? Sorry, I don't know a whole lot about clutching?
