murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Thinking of experimenting a bit, 3-3 wrap on secondary and ton of weight in the tip?
- Apr 14, 2003
- Hessel, Michigan
Yes
rx1 fern
Quick question , if I add more weight in the middle is the sled gonna pull it or is it gonna be to heavy . Right now I have 1 inch in the heel and mid empty with a steel bolt and thick washer .should I put weight in the middle where it's empty right now . Thanks for the help
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Aluminum with thin washer , you'll be surprised.Quick question , if I add more weight in the middle is the sled gonna pull it or is it gonna be to heavy . Right now I have 1 inch in the heel and mid empty with a steel bolt and thick washer .should I put weight in the middle where it's empty right now . Thanks for the help
- Apr 14, 2003
- Hessel, Michigan
Just have to try it and see. Some Vipers like it and some don't.
Most I have seen like a little weight in the center.
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
So what should I use on my sled. I got mcx270 and have the HHY68 weights. Should I go for so much weight I can in the tip? what does the middle weight do? I'm goin to field test the weights tomorrow and trying to get it close to 8700
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Start with 3/8 steel bolt and thick washer in tip, 3/8 aluminum and thin washer in mid, and 3/4 set screw in heel. Check and adjust from there. If you are still high on top end add to tip until you are at 8750. Then add to mid until you get to 8700. I have a stage 1 OSP and i am 58g base, 7/16 steel tip, 3/8 aluminum and thick washer in mid, 3/4 setscrew in heel with O-P-O spring and 46/40 helix set at 6-1 for reference. PM me directly for more info after you try this if you need more help.
briane
- Jul 24, 2016
- Iron Mountain MI
- 2015 SR VIper LTX SE
I just installed a Big Venom kit on my stock ltx se. No studs. Will the factory belt work okay? I've heard some guys are switching to gates carbon fiber. I'm sure this has already been discussed at some point but I didn't want to weed through 40 pages of threads
fasteddie15x
- Jan 20, 2014
If you want to run the 8JP equivalent (stock belt).....use the gates 40C4313
This is a carbon fiber belt. This belt will last much longer than the yamaha belt
- Apr 14, 2003
- Hessel, Michigan
and grip better......
Stock belt will work with the kit, but washers may be needed as the rpms will be higher with the stock 8JP belt due to just a little more slippage than the Gates belt.
briane
- Jul 24, 2016
- Iron Mountain MI
I've installed the carbon fiber. 40c4340. (8dn length) I've added shim washers and the belt deflection looks good.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
mikechm3
- Oct 16, 2015
- 2015 Yamaha STX-DX
- Brights Grove
Hey guys, new here. Im pretty much doing the same install. TP big venom, gates 40C4340 on a stock stxdx. Just wondering where you get these shim washers for the deflection ajd. Or will any equal washers do? Blew my budget for now cause picked up the shaper bars too. Cant afford the new belt adjuster...lol. Thanks.
shagman
Vendor
- Feb 18, 2014
Dealer or Hardware store. Just make sure they are the same thickness. 1mm thick.
