briane
- Jul 24, 2016
- Iron Mountain MI
- 2015 SR VIper LTX SE
I used hardware store washers stacked with the thinner Yamaha washers. The hardware washers were .045 thick. Make sure the washer outside diameter is smaller than the machined surface area so it sits flat.
rbell14
Who has the best pricing on the Gates Carbon Fiber Belts (8DN or 8JP). Where is everyone buying them from?
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Rock auto, Amazon, eBay, $85 is a good price, look for free shipping and no tax.
- Apr 14, 2003
- Hessel, Michigan
Just an update:
The Thunder Products clutch kit comes with everything you need to have the best clutch kit out there, for stock applications and with sleds that are modded with airbox, exhaust and ECU flash. The kit includes Thunder Products glide washers, Thunder Products fully adjustable weights, Clamp that will hold the primary sheaves together so you can pull the weights out without tearing the clutch apart and secondary spring that will not coil bind.
Lots of comments from people who aren't even TY members saying they put the kit in because their Vipers wouldn't even run 86 mph, but after installing the kit are as much as 102mph with everything else stock!
Thunder Products also has a new Belt Adjuster/Belt Removal that works awesome!
mikechm3
- Oct 16, 2015
- 2015 Yamaha STX-DX
- Brights Grove
I bought a Big Venom Kit off someone that never ended up installing it. The weight written on the box is 48.2. Is this setup correct for a stock sled. Not much of a tuner and new to clutching. Again my sled has no mods. Your youtube install looks pretty straight forward so I'm gonna give it a shot.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Yep the 48 is the correct for stock sled just ordered venom kit and spoke to Lon yesterday. Lon at Thunderproducts fine tunes the weights depending on weight, sled/track and riding style.
- Apr 14, 2003
- Hessel, Michigan
For anyone running a stock viper
48.2 Heavy Hitters base – ¾ Allen in heel, 3/8 aluminum in center with 3/8 aluminum and a thick washer in the tip. Stock primary spring (Blue Silver Blue) with a glide washer on each end of the primary spring. Secondary setup was Midnight Blue set at 6-2 with the stock 43° helix
mikechm3
- Oct 16, 2015
- Brights Grove
Perfect, thanks NOS PRO!
JAZZ04RX1
- Dec 28, 2003
- Illinois
- 2016 SR Viper LTX-LE
Hey NOS, just installed my kit this weekend but set the secondary spring to 6-1. I see you recommend to set it at 6-2. I have a 2016 NA Viper LTX with MBRP trail can and studs. Should I change to 6-2?
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Only difference I found was in engine braking when letting off of throttle. Tried 6-1,6-2, one coasted better, sorry forgot which one though.Hey NOS, just installed my kit this weekend but set the secondary spring to 6-1. I see you recommend to set it at 6-2. I have a 2016 NA Viper LTX with MBRP trail can and studs. Should I change to 6-2?
- Apr 14, 2003
- Hessel, Michigan
Jazz, if you are going to be driving trail....leave it at 6-1. If you will be doing off-trail, switch it to 6-2.
6-1 will coast more ( and shift faster ) like swampcat mentioned.
JAZZ04RX1
- Dec 28, 2003
- Illinois
Thanks guys for the replies
Skytt
- Mar 8, 2016
- North
- Sweden
- Viper MTX 162" - 15
Just got myself a kit as well. Sled is Stock MTX 162" -15 with Stingrays airbox mod, does this setup work for me as well or do I need to change anything? Thanks!
- Apr 14, 2003
- Hessel, Michigan
Skytt, What elevation will you be running? If around 5,000 ft, you should be close with that setup, but the airbox mod will pull more air so you will probably make more power. At 11,000 ft. I had the 1/4 allen buried in the heel followed by the 3/4 allen so I had 1 inch in the heel. Then I had a 3/8 steel in the tip only. Worked good.
If you are at lower elevation (under 3,000 ft.) I would keep the center hole a 3/8 aluminum, but would change the tip weight to a 3/8 steel with a thick washer. if you are too high or close to the rev limiter, then put in a 7/16 steel in the tip with no washer.
Skytt
- Mar 8, 2016
- North
- Sweden
Since the highest mountain in Sweden is about 6900 ft, I will be driving 90% of the time below 1700ft.
So ill try 3/4 Allen, 3/8 aluminium and 3/8 steel with thick washer.
How does that sound? I know its very personal how you like your setup but im trying to get a starting Point since we dont have any snow yet.
Thanks a lot NOS
Thanks a lot NOS
