![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
No belt slipping on mine. Dead nuts consistant every time within 5 rpm. Mine also spins the track when stuck in snow. 9025 for Straightline header and 9100 for EVO.Not with these weights Cannondale, these Heavy Hitter weights seem to have more oomph on bottom and mid range when heavier in the tip. Belt slipping? Probably as I noticed the belt temps were higher.
rx1 fern
just ordered a 48/40 helix for my viper ltx se .what is a good weight setup for 500 ft snow drags .i set mine up the way lonn does and it hits rev limiter on take off .right now it pulls good but i hate the hitting rev limiter .looking for a good drag race setup .thanks for any advice.also my setup is k&n filters with a fuel programmer and the venom kit.
- Apr 14, 2003
- Hessel, Michigan
The 48 will help with the rev limiter on take off. The 40 finish angle will keep your revs up more so you can add weight to the tip. 500 feet.....try this
1 inch screws in th heel (1/4 buried and 3/4 right behind)
middle - nothing
tip - 3/8 steel bolt with thick washer if running 8DN (if running the Gates belt put the aluminum 3/8 with 1 thin washer in the tip)
rx1 fern
sorry meant to write a 46/40 helix not 48 .still the same setup nos pro .ill try it out on weekend against the nytro to see .thank you
- Apr 14, 2003
- Hessel, Michigan
You betcha bud!
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
So, are you running the stage 4 with the stock header.I've got the evo stage 4, can and airbox mod.
I have one aluminum in the tip running about 9400+-.
How much more weight wood I add to bring it under 9000. I'll give it a try this week.
trevorl1
- Mar 14, 2015
- Nova Scotia
- 2014 sr viper xtx-se
Yes I had fitment issues with the evo header and would rather my engine run a little rich then have a header rubbing on my valve cover.So, are you running the stage 4 with the stock header.
- Apr 14, 2003
- Hessel, Michigan
Stock header will run fine with the EVO stage 4.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Trail conditions were awesome yesterday, hit 108 with the Big venom clutch kit, and no my sled is not turboed!!
rx1 fern
whats your weight setup and mods to sled murdered137
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
15' ltx dx, ulmers intake (3k&N filters), sandales can, gate's carbon fiber belt, bv clutch kit, 6-1,1" in heel, aluminum with thin washer middle, and 3/8 steel with thick washer in tip, was getting 98 consistently, took a long straight away to get the 108 .whats your weight setup and mods to sled murdered137
trevorl1
- Mar 14, 2015
- Nova Scotia
I tried putting the 3/8 steel and thick washer in the tip but I couldn't get it tight since there wasn't enough threads on the bolt with the thick washer.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Ya, there isn't much thread , I dipped mine in blue locktite and snugged er up, did over 400 mile's this weekend, everything is fine, try 2 thin washer's if you're worried, should be very close.I tried putting the 3/8 steel and thick washer in the tip but I couldn't get it tight since there wasn't enough threads on the bolt with the thick washer.
Alsim
- Oct 6, 2014
- LTX SE 2018
Good number murdered137. At what rpm did you run it? Is the Gates 8dn length ?15' ltx dx, ulmers intake (3k&N filters), sandales can, gate's carbon fiber belt, bv clutch kit, 6-1,1" in heel, aluminum with thin washer middle, and 3/8 steel with thick washer in tip, was getting 98 consistently, took a long straight away to get the 108 .
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Yes , 8 dn lenght, it keeps me off the rev limiter and keeps rpm 200-300 lower, which makes it pull harder Imo.Good number murdered137. Is the Gates 8dn length ?
