- Apr 14, 2003
- Hessel, Michigan
What gearing to use in a ltx se to see 100mph with the big venom kit? Im only seeing 94-95mph
@shagman at work now....is J2hizzo only geared for 95-96?
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Should be 105 @ 9000 rpm with Ltx se.
- Apr 14, 2003
- Hessel, Michigan
So more rpm?
J2hizzo
- Nov 15, 2010
- N.maine
- Srx 700
Got 96 out of it todqy on a long pull...rpms start at 8775 and go up to 8975So more rpm?
Skytt
- Mar 8, 2016
- North
- Sweden
- Viper MTX 162" - 15
Since the highest mountain in Sweden is about 6900 ft, I will be driving 90% of the time below 1700ft.
So ill try 3/4 Allen, 3/8 aluminium and 3/8 steel with thick washer.
How does that sound? I know its very personal how you like your setup but im trying to get a starting Point since we dont have any snow yet.
Thanks a lot NOS
Just tried the sled in some real snow and wow really Love it. Its finally the sled I wanted.
The only problem is that im hitting the rev limiter like crazy
When im gunning it in powder i hit the limit fast but on the trail it takes a while and if i pull slowly over say a lake, it goes fast to 8800 and then slowly climbs to 9100 and then brap brap brap limiter
Should i add weight at the top only or both top and middle?
Is it possible to change bolts in the weights with the weights still on the sled?
shagman
Vendor
- Feb 18, 2014
That's a little better. What were the snow conditions.
shagman
Vendor
- Feb 18, 2014
Take the 3/8 aluminum out of the middle and replace with 3/8 steel in the middle. That will make it pull even harder down low to mid and reduce final rpm a little. Report back.
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Ok, looking for a bit of remaining fine tuning adjustment to bring my RPM's down by 200 - 300 RPM. I currently have Ulmer's Header, Hindle Can, and Ulmer's airbox mod.
My current Heavy Hitter setup is the following:
1" Allen in Heel
3/8 Aluminum with 1 thin washer in Middle
7/16 Steel with 1 thick washer and 2 thin washers in Tip.
I'm very happy with the setup but need to get my RPM's down by 200 - 300 as I'm hitting the Rev Limiter. Problem is, I can't seem to find out what weight combination I can use in the Tip to bring the RPM's down a bit. Currently I have 6.4 grams in the Tip. Yesterday I tried 7 grams but it was a bit too much. 6.6 grams in the Tip would probably be perfect, but I can't find a combination with the supplied weights that get me to 6.6 grams. If a Brass Bolt 1/2" Head would be an option for the HH, I could get to the 6.6 grams, but I don't think they are offered. If not, would you recommend maybe adding a bit more weight to the middle to get some of the RPM's down?
I'm getting close, just need to figure out if adding weight to the middle would be the ticket or not. Thanks!
1" Allen in Heel
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Here's a little inside info, the gate's carbon fiber belt will bring your rpms down by 200- 300, and keep you off the limiter for the most part, already been through it, trust me.Ok, looking for a bit of remaining fine tuning adjustment to bring my RPM's down by 200 - 300 RPM. I currently have Ulmer's Header, Hindle Can, and Ulmer's airbox mod.
1" Allen in Heel
shagman
Vendor
- Feb 18, 2014
1" Allen in Heel
We need to add to your middle so that you have some room for adjustment in the tip. Put 3/8 steel with 1 thin washer in mid. Also what spring are you running.
putz21
- Apr 15, 2013
- Tomahawk, WI
Forgot to mention I have the Gates Carbon Fiber belt on already.
shagman
Vendor
- Feb 18, 2014
What spring.
putz21
- Apr 15, 2013
- Tomahawk, WI
I have the OYO primary spring and a 46/40 HelixWhat spring.
shagman
Vendor
- Feb 18, 2014
Add what I said earlier in the middle. Steel with thin washer.
putz21
- Apr 15, 2013
- Tomahawk, WI
Should I then remove some weight from the Tip if I add the Middle with 3/8" Steel with Thin Washer or just leave it alone? That's a 1.2 gram difference between the 3/8" Steel w/thin washer vs. 3/8" Aluminum w/thin washer.
