chaleurphantom
- Oct 5, 2009
- Northern New Brunswick, Canada
- 2018 SIDEWINDER LTX-LE 50th Anniversary
2016 VIPER XTX LE - WHITE,
2009 VENTURE GT,
1995 POLARIS INDY 500,
1984 SKI-DOO CITATION 3500
My kit did not come with 1" Allen Head set screws. Is there a reason for this? I only have 3/4, 1/2 & 1/4 ". I was thinking of adding a 1" set screw to the bottom. I hit the rev. limiter on take off. I have the small weights, normally aspirated. Will the 1" set screw interfere with weight movement?
rbell14
Not sure a 1" allen is normally part of the kit. I did not have one.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
1" is not included in the kit, burry 1/4", then 3/4" behind it.Not sure a 1" allen is normally part of the kit. I did not have one.
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
I picked up some 1" set screws. I looked into a 1/4" and 3/4". The combined weight is more than I would like. I weighed the 1" at 3.85 gms. Should a 1" length be used is the question.
- Apr 14, 2003
- Hessel, Michigan
Yes, it can be used .... just swing the weight when installed to see if it clears.
chaleurphantom
- Oct 5, 2009
2009 VENTURE GT,
Thanks, I will check that out.Yes, it can be used .... just swing the weight when installed to see if it clears.
connor wilson
- Jan 5, 2016
- keswick ont
- 2016 sr viper ltx se
installed my big venom kit, pulls very hard, feels good, but i struggle to get 140kph out of the sled now, completely falls on its face at 135kph and creeps to 140... what are you suggestions? it running around 8800rpm wot
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
Here is a video of me playing in deep snow when testing the Big Venom kit. T
Which sled in your signature is this?
- Apr 14, 2003
- Hessel, Michigan
My 2014 Viper. Same as the one in my profile pic
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
Thats nuts! I figured it was the sidewinder for how easily that thing just stands right up!
I ordered my kit this AM, Lonn is sending it Speedee so it'll be here tomorrow.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
I was under the impression that when you provided Lonn your setup during ordering, the kit would come with at least a starting point of weights installed?
My kit is here, and I am in the middle of installing it. When I grabbed the weights out of the box, they are completely empty, nothing in any of the positions. This is the first time I have ever done a clutch kit in a sled, and I have no idea where to even start.
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Tip 3/8 steel bolt + 1 thin washer
Middle 3/8 aluminum bolt
Heel 1/4" set screw buried then 3/4" on top. Make sure the weights do full swing.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Start with 3/4 allen in the heel, 3/8 aluminum and one thin washer in the middle, and 3/8 steel with 1 thin washer in the tip. If it hits rev limiter hard on take off, you'll need to bury a 1/4" allen under the 3/4. Wrap secondary at 3-3. That should be close for starters.I was under the impression that when you provided Lonn your setup during ordering, the kit would come with at least a starting point of weights installed?
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
Is this for a stock baseline setup? Does swapping to a 1.6" Ice Cobra, or any of the mods in my sig make any difference?
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
Damn, it happened again. Both typing at the same time.Tip 3/8 steel bolt + 1 thin washer
