hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I'm betting the bushing is fine and it's belt dust build up! My apex had 17000km with original bushing ,just regular cleaning and they were hard km.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
I just installed a brand new belt for that trip 8JP and the clutches do look pretty dirty so maybe that's the problem...just really dirty.I'm betting the bushing is fine and it's belt dust build up! My apex had 17000km with original bushing ,just regular cleaning and they were hard km.
hellflyer
- Dec 2, 2008
I just installed a brand new belt for that trip 8JP and the clutches do look pretty dirty so maybe that's the problem...just really dirty.[/QUOTE
I ran the 8dn before for 2000km and nothing for belt dust.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
I put about 4500kms on my original 8JP and never had any problems. Blew clutches out half way through season and kept going...no problems until new belt or so it seems..
hellflyer
- Dec 2, 2008
I tried blowing them out but it didn't seem to do anything. Major scrubbing with degreaser and then water and dawn. Then grease and wax remover on the faces.
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
Didn't really think the thread was off track, but ok! Lol
CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
What is everybody's thoughts on the clutch kit having an effect on the bushing? I honestly don't think it will, especially when I've only used the kit for less than 1000km...I'm under the impression it was just a faulty product from factory. I know when you start changing things (some) it might have an effect on something else...but I can't really see the kit being the culprit here...
hellflyer
- Dec 2, 2008
Shouldn't have any effect on bushing wear!
Skytt
- Mar 8, 2016
- North
- Sweden
- Phazer MTX -08
Can anyone tell me the specs for the midnight blue secondary spring that i have ? 38-100lb comp, 50lb/in. twist? Couldnt find it. Would be nice to know so I could compare it with others springs and stock spring
mattchew_3
- Dec 28, 2014
- SR Viper
Does the max rmp ever reset.?..mine read 0 when I hold the button. Messing with the kit before I put it away so I remember where I'm at for next season
It is at the dealer for an oil change and asked them to look at it. The clock was not working either just reading 1200...they say nothing is wrong with the cluster. I have a year left of YES so this should all be covered
Sent from my SM-G920R6 using Tapatalk
Max rpm resets every time sled is turned off.
Kkurz
- Nov 1, 2016
- Peterborough On.
- 2014 XF7000 Sno-Pro Limited
(Yamaha powered)
I noticed that the clock goes back to 12:00 every time you disconnect the gauge to remove the hood. Also if the battery is disconnected or if it dies. Could that be part of your problem?
JCviper
- Feb 27, 2016
- Morrice, Michigan
- 2016 SR Viper LTX-DX
- YAHOO
- jcstang06@yahoo.com
- Jcgoblue2
Without any other mods?We have seen 103 to 105 mph on most sleds on good snow conditions.
yamamn
- Jan 24, 2016
- central mn
- 2014 viper ltx se
2014 viper ltx
2007 phazer gt
2007 phazer gt
2002 viper
1997 sx 700
Have a question on starting point. Going to add an ulmer can and evo stage 2.5 flash, does anyone have a good starting point for the heavy hitters? Thanks 2014 viper ltx se
PM Shagman or NosPro they will hook you up.Have a question on starting point. Going to add an ulmer can and evo stage 2.5 flash, does anyone have a good starting point for the heavy hitters? Thanks 2014 viper ltx se
- Locked
