BombaPolaYama
That's about the same feeling I get from my 2010 Venture TF - very difficult to control the throttle for smooth engagement. Would like to do something to make it smoother but will wait until it is broken in first. And sometimes it also seems when slowing quickly and going again that there is some sticking/binding of the belt going on - like it will rev up more than necessary before engaging and it is like you can feel it releasing.iasledder said:Interesting. My '10 ltx doesn't engage too soon, but it is very harsh, always has been, making it hard to do a feather engagement, very jerky and could be dangerous if not expecting it.
iasledder
Ordered spring from Allen yesterday.
jarmentrout
3000 seems about the same as my ventures. Are the clutch shives smooth? Is the choke disengaged? What's the idle set at?
grumpysanta
is the clutch clean ? if its dirty with belt debris it wil snap to engage and feel harsh..
CaptCaper
- Jan 1, 2007
- Northern N.H.
I've cleaned and new belts,etc. I'll try a spring. Just don't know which one.
grumpysanta
ask advice where you will buy ,tell them what you want ,,ie for your wife
iasledder
As advised, contact Ulmer, tell him your problem and ask for the spring for your sled. srxspec@gwtc.net <srxspec@gwtc.net>;
iasledder
Got my spring from Ulmer. It does the job, no more wheely starts. Smooth like my wifes Polaris.
CaptCaper
- Jan 1, 2007
- Northern N.H.
Good..to hear. Did he ask what color was there OEM ?
iasledder
No, but the OEM is black and so is Ulmer's. The coil dia and length of Ulmer's is different. Track engagement, on jack stand, OEM 3500, Ulmer's 3000.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
Is it noticibly smoother on start? My 2010 vector is abit harsh as well.
I wonder If it will greatly affect acceleration?
Yamadoo
Yamadoo
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
Hartman has a P-85 Polaris type primary designed for Yamahas. My question is would that get rid of the primary noise at idle? Being familiar with Polaris primaries, it should make for a smooth engagement.
yamadoo
- Jun 3, 2003
The Polaris clutch does not get rid of the idle rattle, there is a great thread on this being related to the splined stub shaft which is designed to protect the crank bearing.
I think the different spring is an interesting idea. Concerned though do not want to lose acceleration or back shift. Maybe those with clutch knowledge can chime in
Yamadoo
Yamadoo
Vectornut
- Nov 18, 2007
- Eden, Vermont
- RS Vector
YAMADOO. Thanks for the quick answer to my question. I really appreciate it. I quess it is the splined stub shaft along with the 3 cylinder cadance causing all that noise. My riding partner has a Ski-Doo 1200 and it suffers from the same clatter at the primary clutch just like my Vector.
CaptCaper
- Jan 1, 2007
- Northern N.H.
Definitely more rattle,noise then my Attak.Not as smooth on take off. Makes me wonder why they set it up that way.
