DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE w/EPS
18 Winder LTX LE W/EPS
97 SX Vmax 600
Looking forward to opening the chaincase this off season. My riding buddy (18 Tcat) and I (18 Winder) both have the DMC gear and have 2500 miles on them this year. Hoping to report some good info on the results of a season running this gear.
Pstn head
TnxsDMC will last life of the sled!
markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
well the repair is complete, it was super easy, I replaced with an OEM 22 tooth as I got it fast and was back on the trail quickly.
The OEM lasted 6000 miles in my machine with PowerTrail tune and aggressive riding. I always use 75/90 synthetic gearlube vs Yamalube and I will continue to as it clearly worked well...
Dave385
- Nov 12, 2017
- Michigan
- 2018 Yamaha Sidewinder
2008 F1000
2007 F1000
2007 F1000
- Lapeer Michigan
Farmer 73
- Feb 20, 2015
- 2010 NYTRO RTX SE, 2012 VECTOR, 2001 SXR 600, 2001 PHAZER, 2000 PHAZER, 1983 ENTICER EXCELL III
I would like to replace my top gear with the DMC gear. It is for my 2022 Winder LTX GT. I might be on borrowed time with 3000 miles on her. I want to keep it stock. I have not pulled it apart yet, so I don't know what tooth gear is in there! Is it 21, 22 or what. Does anybody know off hand?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
21T
I get the wanting to keep it stock, but since this one area that was under-engineered, I would highly recommend either installing the harder bushing in the gear you have or switching out to one of the other aftermarket options.I would like to replace my top gear with the DMC gear. It is for my 2022 Winder LTX GT. I might be on borrowed time with 3000 miles on her. I want to keep it stock. I have not pulled it apart yet, so I don't know what tooth gear is in there! Is it 21, 22 or what. Does anybody know off hand?
Farmer 73
- Feb 20, 2015
Definitely going with the DMC route when they become available!I get the wanting to keep it stock, but since this one area that was under-engineered, I would highly recommend either installing the harder bushing in the gear you have or switching out to one of the other aftermarket options.
markt111
- Feb 10, 2017
- Topsfield, Ma
- all Yamahas
The stock gear is a 21, the 22 will give you a bit more top end!I would like to replace my top gear with the DMC gear. It is for my 2022 Winder LTX GT. I might be on borrowed time with 3000 miles on her. I want to keep it stock. I have not pulled it apart yet, so I don't know what tooth gear is in there! Is it 21, 22 or what. Does anybody know off hand?
Farmer 73
- Feb 20, 2015
Great idea but stock for stock there is not much out there that will beat it but maybe another sidewinder! The stock gearing will keep the trail riding smooth and linear, which is so amazing with this missle of a sled! Just so sad that this will be the last sled Yamaha can hang its hat on. I just can't see anyone of the other companies topping this engine for what it is!The stock gear is a 21, the 22 will give you a bit more top end!
Clintww
- Mar 6, 2022
- Central MN
- 2001 SXR. 2005 RX1. 2017 Sidewinder
- MN
The other aspect of switching top gear could be fuel mileage. I never see it mentioned that if you are traveling 60 MPH with either gear, the RPMs should be lower with the 22 gear. Less RPMs over a day has to make a little difference. I switched mine out this offseason and installed adjustable weights. In stock form I think they run a bit high in RPMs while cruising. I'm also adding the Hurricane SM tune to get to 225 or 240 HP. Maybe that would pull a larger gear yet. Can't wait to try it out.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
It will also be a slight bit slower to reach speed and it will be a bit faster top end. Its only 4% difference in gearing so it isn't a huge difference
Top is SRX stock, middle is TCAT 24/50, bottom is 22/41 gearing
acpantera
- Sep 25, 2004
- W.N.Y.
- 22 TCAT+ATAC+EPS
I think it's been said that the larger gear is easier on the bushing. I changed the stock 24t with a DMC 24t at 4,000 miles but the bushing wasn't bad at all.
Clintww
- Mar 6, 2022
- Central MN
- MN
But add a tune and a little bit of clutch adjustment.. Is it still slower to reach speed? And it should still have power to pull max RPM at the higher top speed. I have read here the tune will improve fuel economy too. Will I get the fuel economy to match my Sons 2009 Vector? I consistently use a gallon more per fill up. Not all that important, but if any of what I stated turns out to work, I will be happy. From what I recall it turns closer to 6000 rpm at 60 mph I like seeing it only drops 200 rpm, but i wonder if it could be more without becoming a dog.It will also be a slight bit slower to reach speed and it will be a bit faster top end. Its only 4% difference in gearing so it isn't a huge difference
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Put the 300 super spool tune from Hurricane, 22 top gear and a steeper helix and let her eat!
All depends on how fast and quick you really want to go.
- 19K
