hankthetank
doing a turbo install and getting different answers on how to torque down the head with 3 gaskets. Whats the best way to do it?
htt
htt
Skydog
Cross from center out. 38FT
I have heard from a few people that did 50lbs and pulled the stud out of the block!
This is how i did mine and the gaskets where dry.
Skydog
Skydog
TurboTony
I did mine as per yamaha, something like 12 ft lbs plus 120 degrees? I can't remeber the specs off hand.
I'm using a headshim though, so that may make a difference
Tony
Tony
I did it per the Yamaha specs as well, 14lbs + 121,105, and 140* depending on which bolt. Its page 5-20 in the service manual.
Haven't got to test yet, still waiting on...
...parts
...parts
hankthetank
skydog
20 nm=14.75 foot pounds
35 nm=25.81 foot pounds
50 nm=36.87 foot pounds
are these conversions correct if so i will use this method.
htt
htt
20 nm ~ 14ft lb
Here's the service manual page if it helps...
