Track/cooler protector
Kevin0311
NY
2007 Phazer FX
So i currently own 3 2007 phazers one base and two fx models, have tinkered with one base and one fx no surprises now the third (fx one) went to take front off chassis and there are two cooler protectors rivited to the front sub frame i had to drill out to get front off, they go all the way up tunnel. Why would one fx have but other not? Blue tan is one with and team blue/white does not (This one has deeper lug track not oem).
on a side note thinking of selling the team blue/white one with reverse thoughts on asking price, complete fluid and filter change, one ball joint replaced, sparkplugs new and anything else that needed replacing, no windshield or bracket currently on it. 6600 miles
Thats strange, you get them both new or used?
All 3 bought used last year all different owners
Photos
looked at one that doesnt have them and no rivit holes like was there in the past and removed for deeper lug track
Strange like soposed to be there or never seen it before? Looks like a good install if not a oem setup.
Strange that they are not the same. I thought mine was not on when I had an FX but can’t recall. We did distroy heat exchanger with a stud and turned into insurance.
might have been missing then on the 09 phazer rtx i made into an xtx with 1-1/2" lug track as i had lots of room/clearance with the 9 tooth drivers.
could they have been added like the ones used to be availible for the sxr sleds?
