track grinding?
tuner
Blanc-Sablon, Canada
When I drive at walking speed or little faster it sounds like the flap is stuck in the tunnel, but its not. Could this be any bearings? I seems like its the rear idler's, that's why I'm worried. If they fail, at my usual speed I am #$%&* . Any help would be great. For such an expensive snowmobile ( 2007 ATTAK GT) I hope I don't need bearings already!?! Do I?
Vibration
Check to see if your track tension adjusters are facing in or out, they are slightly offset and can get spun around if you have taken off the rear axle. THe nuts on the backside will make contact with the lugs on the inside of the track and cause a vibration. You can also tell if there are wear marks on the inside side of the inside lugs. This was the case on the 05 skid that I bought from a guy on TY.
I sold the skid but I believe they should be facing the center of the track???
