Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
9224H - 137" x 14" wide x 1" 2.86 ripzaw II
9010H - 14" Wide Hacksaw 136 x 14 x 1, 2.52" pitch, Two ply, Full clip, This is a 15" wide track we narrow.
Assuming the 136" will work with 10t 2.52 drivers, what's going to be the difference?
Does one have a sizable advantage over the other? if so, what would that advantage be?
Note: I'm already gear limited to 130mph. So is there any benefit to go to 1"??
Thanks guys!!
Thanks guys!!
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
136 with 10t drivers works
2.52 pitch is quicker and also provides more bars for studs .
1 in track and 14 in , is ok if your on ice or hard pack, also allows u to run shorter studs for less rotating mass.
All depends on what racing/playing your setting up for
Doc Harley
- Oct 17, 2016
- Here & there
NYT, Understand your thought process. Thank you for your sharing your knowledge.136 with 10t drivers works
My style: I ride like I'm 80yrs old and race like a kid. My axle is worn, was able to tighten up the .020 clearance with shim stock. (Thanks, fords4life) held up for 3 seasons! Track is original. So, the additional cost would just be the drivers.
"Sideshowbob" posted up the replacement Cat axle (w/drivers) on another post.
So ill head in that direction. Ty....
Turboflash
- Mar 18, 2019
- Southern MN
Lol. If I had known then what I know now, I'd have started testing/experimenting way before I did.NYT, Understand your thought process. Thank you for your sharing your knowledge.
For me, I should have decided way before I did, if I want to drag race 660-1000-1250 ft. or race top end at 1/4-1/2-3/4 mile.
I learn slow.
Doc Harley
- Oct 17, 2016
- Here & there
Focus, Focus....lol! John, Youre going in a similar direction that i am. We can't run thru the trails like Fleecer & gang at a 150+.. my helmet would fly off, and my head would be in it. The sport is changing for all of us. If I dont fart around with this sled and chase stupid $hit, idk what I'd do?!?!Lol. If I had known then what I know now, I'd have started testing/experimenting way before I did.
I learn slow.
I'd rather be riding like it was 10yrs ago.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
If you're going to do it, do it right and put Avid 2.52 drivers on. The 2.52 track pitch is freer rolling and will run more mph up top, if that's what you're after. Trail rider, I don't like the 1" track unless you're always hard pack, but that's just my opinion. I will say I just did a Sidewinder converted to 2.52" drive and it was worth 3-4 track hp over the 2.86 pitch.
Doc Harley
- Oct 17, 2016
- Here & there
Cat axle w/drivers $385
Avid drivers & axle $580
What is it about the avid drivers vs stock that stands out, in respect to 1,000ft runs?
And a few fly bys @ 130mph+/-
Very slow by today's standards
- Apr 17, 2003
- Menno, SD
- Menno, SD
They are 100% machined versus molded, run truer and are stronger than the OEM Cat ones. If you're going to buy a track, stud it, and change it, do it right, do it once.
Doc Harley
- Oct 17, 2016
- Here & there
Overlooked facts...ty
Doc Harley
- Oct 17, 2016
- Here & there
I have brand new 1.63 on a 1.25 track. Will the 1.63 be OK on a 1" lug track? If not would 1.5's be more appropriate?
I had to ask...
I had to ask...
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
In my opinion 1.63s woodys i assume are too long on a one inch track.
Turboflash
- Mar 18, 2019
- Southern MN
IMO, 1.575 Woodys are about limit (for trail riding) on a 1.25". For sure too long for 1" track.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
If you have decided on a 1 inch track everything about the Hacksaw is better in my opinion. The things already mentioned and the Hacksaw is a bit better in the snow in my experience. Now 1 inch tracks suck in the snow but I mean if comparing the 2 and more interested in top speed.9224H - 137" x 14" wide x 1" 2.86 ripzaw II
Thanks guys!!
Doc Harley
- Oct 17, 2016
- Here & there
Just trying to put everything into perspective and consider my options as I navigate this sport.If you have decided on a 1 inch track everything about the Hacksaw is better in my opinion. The things already mentioned and the Hacksaw is a bit better in the snow in my experience. Now 1 inch tracks suck in the snow but I mean if comparing the 2 and more interested in top speed.
