monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
Had my first shakedown run today after pulling the skid.
Just wondering what the track tension should be?
Up on the stand, I've got 5/8" slack sitting there. Is that ok?
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
I run the two fingers under the center wheels with no slip driver's.
monte1214
- Apr 20, 2005
- Durham Region, ON
APEX 06 said:I run the two fingers under the center wheels with no slip driver's.
Not quite sure what you mean by that?
he means his sags abot 1.5" in the middle between the sliders and the clips. he also runs extrovert drivers so he can run his track looser.
my old rx has about 1/2" of sag running extroverts. stock drivers i had to run it tight as it tended to ratchet.
the new xtx is not home yet.
monte1214
- Apr 20, 2005
- Durham Region, ON
1.5"??
Like I said, mine only has 5/8" sag.
Is that about right in a stock set up?
if it is not ratcheting under hard acceleration, yes it is fine. if not tighten it untill it stops is usually the rule of thumb.
monte1214
- Apr 20, 2005
- Durham Region, ON
It's not ratcheting, so I'll leave it be.
Thanks for the help!!
theCATman
- Feb 19, 2007
- WI
- Yamaha
I run 1-1 1/4" free sag on the Apex (regular drivers)
And 1.5-1.75" free sag on the Vector (anti-slip drivers)
I don't know why the F^ck Yamaha recommends such tight track tension. Must be part of their market ploy to sell hyfax.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
- '17 Sidewinder LTX DX
I run about 1 1/2 " free sag on my Apex with standard drivers. I have never ratcheted but I had some exhaust system damage last year when I let it get looser than that back when I had a studded track.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
1 1/8" with 20 lbs. of pressure is factory spec.
Blue Dave
- Jan 7, 2008
- Ham Lake, MN
stevewithOCD said:1 1/8" with 20 lbs. of pressure is factory spec.
I tried the factory spec. once and like many other guys I found that to be much too tight IMO.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
monte1214 said:It's not ratcheting, so I'll leave it be.
John, try running it loser. 5/8th's to me is still too tight.
Like I told you before, mine is almost at 1 1/2"'s of free hanging sag and I get zero ratcheting.
Maybe the LTX's are different and need to be a little tighter, I don't know, but I would at least take your's to a full inch and see what happens?
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
Go to 1 1/4" with 20 lbs. & cold track. Too loose & you may cause problems & could slow down. This has been proven over & over especially by people like Mike Knapp. Studs hitting things like the tunnel is NOT good & for what gain? Running looser will not stop hyfax wear or gain speed. Measuring sag is an inaccurate way to measure. Some sort of consistant force on track is only true way. If track is cold it will sag less than when warm. I was able to prove this to friends on a lake. We both lost 1 to 2 mph (on speedo) when run loose. We both tightened & loosened tracks 4 TIMES. Every run was faster with 1 1/8". Needless to say we all run that measurement now.
Daranello
Suspended
stevewithOCD said:Go to 1 1/4" with 20 lbs. & cold track. Too loose & you may cause problems & could slow down. This has been proven over & over especially by people like Mike Knapp. Studs hitting things like the tunnel is NOT good & for what gain? Running looser will not stop hyfax wear or gain speed. Measuring sag is an inaccurate way to measure. Some sort of consistant force on track is only true way. If track is cold it will sag less than when warm. I was able to prove this to friends on a lake. We both lost 1 to 2 mph (on speedo) when run loose. We both tightened & loosened tracks 4 TIMES. Every run was faster with 1 1/8". Needless to say we all run that measurement now.
Do u recommend the same for the 128" and 136"?
I agree with Steve. I have seen top end loss with a loose track as well. It is very easy to run the track loose enough so that it balloons and rubs on the top of the tunnel/protectors at speed. I would bet that some you guys running 1.25" + of free sag might find some burnout marks inside your tunnel if you look closely
