stingray719
Bought 3 used 8DN off Ebay, big mistake. They smelled like they had been in a fire but I tried one anyways as I had never seen an 8DN belt fried. But this one was...reeeeeek pop sled lunge reeeek smoke. Don't buy used off Ebay
YamahaTim
- Sep 21, 2013
- Farmington, MN
- 2014 Yamaha Viper LTX SE MPI Turbo
stingray719 said:Bought 3 used 8DN off Ebay, big mistake. They smelled like they had been in a fire but I tried one anyways as I had never seen an 8DN belt fried. But this one was...reeeeeek pop sled lunge reeeek smoke. Don't buy used off Ebay![]()
Lol...not good! I guess new is best!
- Apr 14, 2003
- Hessel, Michigan
Yes, new is best. Mine on my Viper was on my Nytro with about 500 miles on it. Working great! But picking up a new belt for it soon. Also tryng the Gates belt (But one thing at a time as my notes have filled 2 pages already)
bleedyamaha
- Sep 28, 2013
- Northern Iowa
8dn
Ok maybe I missed this. Ppl are switching belts to help with over reving caused by track or belt slipping. So has anybody added a shim to a oem belt before they shimmed a 8dm. Whats the results? Also you talk about belt deflection. How do you adjust that? Shims? Is it still rule of thumb 1 1/2 in center off straight edge.
09nytro
Re: 8dn
1"to 1 1/4"bleedyamaha said:Ok maybe I missed this. Ppl are switching belts to help with over reving caused by track or belt slipping. So has anybody added a shim to a oem belt before they shimmed a 8dm. Whats the results? Also you talk about belt deflection. How do you adjust that? Shims? Is it still rule of thumb 1 1/2 in center off straight edge.![]()
stingray719
Re: 8dn
Put additional washers on 3 bolts in back of secondary until belt ribs ride just above the secondary sheaves. Somebody posted pics a ways back.
stingray719
I bought the Ultimax version of the 8DN and am going to test that just because.
TPAY243
- Apr 14, 2013
- Northern Wis
- 2020 Yamaha Sidewinder LTX SE
Not trying to high jack this tread but i think the reason why u guys are having problems with the stock belt is because of the turbo i dont think that the belt was designed for the added hp kinda the same problem the guys with the modded cats are having just putting it out there all i know is i installed ULLMER clutch kit in my stock viper this cures all problems you guys are having it is faster all the way through bottom to top end and no more rpm hunting that you guys are having best $375 i spent
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Not to sure about that I recently talked to Allen about getting a kit for my sled and he talked me into waiting until he gets his kit dialed in for the 8dn. Told me he is seeing more consistent results and more durability out of the 8dn. Will be switching mine over in the offseason. Put my new spare 8jp and it will suffice for what is left of the seasonTPAY243 said:Not trying to high jack this tread but i think the reason why u guys are having problems with the stock belt is because of the turbo i dont think that the belt was designed for the added hp kinda the same problem the guys with the modded cats are having just putting it out there all i know is i installed ULLMER clutch kit in my stock viper this cures all problems you guys are having it is faster all the way through bottom to top end and no more rpm hunting that you guys are having best $375 i spent
baggs66
- Nov 18, 2007
- chautuaqua co. n.y.
- 06 apex gt
Just tuned in friends sled with ulmer clutching, changed over to 8dn belt and runs much better than stock belt. Smoother and less slippage.
bleedyamaha
- Sep 28, 2013
- Northern Iowa
gates
Well I changed out my original belt with a gates belt. No direction arrows on gates. Hope its on right. Also I checked my ink marks on primary and secondary. The primary was riding 1/2 inch from top and secondary 1/4 inch from top. Took sled down to lake and made some short runs. Still hitting rev limiter but not quite as bad before at bottom end. Lake was blinding and ruff but it got to 85 very quickly but havent seen more yet. Need more time on belt yet. Put a new mark on primary so will be watching. The belt sits flesh with the secondary not above it with both belts. Also when I came to an idle with new belt its chirping for 30 sec. than goes away. Whats your guys thoughts?
allyammies
Mine is not a turbo so thats not it put 8dn on today runs a consistent 8400 rpms so it is not all over the place.Need to get some shims, the belt is sitting down in the secondary so maybe that will bring it up a bit.
YamahaTim
- Sep 21, 2013
- Farmington, MN
allyammies said:Mine is not a turbo so thats not it put 8dn on today runs a consistent 8400 rpms so it is not all over the place.Need to get some shims, the belt is sitting down in the secondary so maybe that will bring it up a bit.
It should help for sure!
YamahaTim
- Sep 21, 2013
- Farmington, MN
Re: gates
While looking down at the belt the. You should be able to read the writing on the belt normal, not up side down
bleedyamaha said:Well I changed out my original belt with a gates belt. No direction arrows on gates. Hope its on right. Also I checked my ink marks on primary and secondary. The primary was riding 1/2 inch from top and secondary 1/4 inch from top. Took sled down to lake and made some short runs. Still hitting rev limiter but not quite as bad before at bottom end. Lake was blinding and ruff but it got to 85 very quickly but havent seen more yet. Need more time on belt yet. Put a new mark on primary so will be watching. The belt sits flesh with the secondary not above it with both belts. Also when I came to an idle with new belt its chirping for 30 sec. than goes away. Whats your guys thoughts?
bleedyamaha
- Sep 28, 2013
- Northern Iowa
writing
Thanks Tim. Thats what I did. Put on 80 miles today on 2 rivers. Trails sucked cause you couldnt see but the rivers were fun. Turkeys bald eagles deer coyote and pheasants. The belt chirping is gone. Very sliippery with new snow falling all day.
