dilligaf
LSXM3 said:My question is why do some seem to have a problem and others such as myself have never ever seen so much as a temp light. I have rode this sled in some really warm conditions and low snow and the light is still phantom to me. What could cause such a variation from sled to sled
I've wondered this myself. In the 4k miles I put on the Nytro, I've never had the temp light come on. And I've done more riding then I like to admit in -20F temps.
It'd be interesting to set up a poll to see who has chronic overheating issues, and whether they've got a trail tank or not. Not sure what other variables would be worth tracking, maybe majority on-trail vs off-trail riding....
09nytro
Most that are over heating have trail tanks.....they are very close if not right on the rad ...my buddy had a 09 nytro like me and he had the trail tank and was always seeing the light put stock tank on and was good.....just doesn't get the air flow through it like it should no air flow no cool....
LM7800
- Dec 4, 2011
- ohio
- 2016 viper ltx LE sold
i still a lack in heat exchager size. and trailtank doesn't have any thing to do with ice build up under tunnel
09nytro
I didn't add any heat exchanger I'm all stock and never overheat ....ride in dirt some times and some times in very cold temps too this week been 0 to -4 and colder
Just saying most of the people that have the problems have trail tanks ...something to look at......
Tyloooor
I can tell you, it's sure is tight in there with a trail tank.......
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
I don't think the Trail Tank is to blame. I had the problem before installing the bigger tank. I can't explain why some don't have the problem but their are plenty of Nytro's running hot regardless of which tank they run. Maybe it's a variation in the tolerance of the temperature sensors. Just to clarify, most of the Nytro's with this problem don't actually overheat, the temperature light comes on which means they are running hot but are not overheating....Yet!
09nytro
I must say I really like that rear heat exchanger ......
What if some one would put that rear one in and get some Togo where the protectors are with the front .... Could you take the rad right out ( I think Polaris made tunnel heat exchangers that were protectors at the same time) been thinking about this
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Mountain Performance sells a tunnel exchanger and rad delete kit that does just that...if you have an XTX or MTX.
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
2012 xtx only once
I have had the light come on once (at idle)and the engine shutdown(@150 miles on engine) Have 600 miles now and have not had a light since. Been riding in marginal snow at 40 deg f and powder @-4 deg f. Lots of ice in the tunnel when cold. Love this sled once I got the suspension right.
Grimm said:Mountain Performance sells a tunnel exchanger and rad delete kit that does just that...if you have an XTX or MTX.
BoonDock Saint
this year i was overheating alot checked out my fuse for the fan was blown out, changed it out and no over heating after like all these years ive been using the trail tank without over heating issues
grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
BoonDock Saint said:this year i was overheating alot checked out my fuse for the fan was blown out, changed it out and no over heating after like all these years ive been using the trail tank without over heating issues
I'd be concerned why the fuse blown. If you haven't shimmed the radiator I'd get that done. It's possible the fan blade hit the tank and stopped it from spinning causing the fuse to blow.
09nytro
I seen that ....won't work on may sled I have a Rtx se ...I will fig something out
xtxcited
I don't have a trail tank and I've had light-on several times on warmer days with or without snow. on cold days when I let it idle. I put a 3/4 spacer behind the radiator and put vents in nose and on top right in front of tank. I can feel a lot of hot coming out of them when my fan kicks in. this year, I ripped out my tunnel protectors and installed the oft close-off plate in hopes of eliminating ice build up. I only have 35 miles on so far this year
, and am still seeing high water temps of 185-200. and it's been really cold in ND!
, and am still seeing high water temps of 185-200. and it's been really cold in ND!xtxcited
I'm still thinking of putting in a tunnel cooler, but will probably make my own that goes down one side and back on the to keep ice build up even. I forgot to mention on the worst day last last year, it seemed like airflow made the biggest difference. the difference between the light coming on or not on a decent day (30-40° day) with lots of fresh powder was hood on or hood pulled off. that's why I put the new vents in.
