yamadooski
I've got a 2006 Apex GT one of my buddies rolled and bent the step up slightly at the rear of the sled. We'll have to order a new heat exchanger since it busted out the rivets and separated and wondered if anyone knows a good way to bend the foot rest back to flat.
Thanks for any info
Thanks for any info
sherlock29
I had a misshap a bunch of years back.... plowed into the back of my buddies sled... bent the rear tunnel all up... i just drilled/dye grind all the rivels out and with blocks of wood and a 20 oz hammer straightened it all back... once everyhting was as as straight as i could get just reasembled... re-revited it all back up... worked great!!! aluminum is quite a maluable metal and easy to work with.
cheers..
cheers..
