jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Found it!
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
YAMAHA SIDEWINDER ARCTIC CAT 9000 998T EXTERNAL FUEL PUMP HARNESS RELAY TURBO | eBay
I use a Bosch 30A mini fuel pump relay encased in a waterproof shrink. There is also an inline fuse to the pump from the battery. It may be receiving 13.5v one minute then the next minute barely receiving 12v.
www.ebay.com
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
- Spring order 2021 srx
2012 Apex xtx
Anyone running a gss 342 with the stock fuel regulator? Any issues or is the regulator a must?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Yes plug and play under seat.Got a link? And is this plug and play? Sits under the seat by battery I assume.
HURRICANE
Check this out. All fuel supply concerns are addressed including the low fuel starvation
Hurricane Fuel Supply Kit - Hurricane Performance
This Hurricane fuel pump and pressure regulator kit is needed for tunes over 300HP on the Sidewinder-Thundercat 998. This kit is designed to fit like OEM and will supply fuel for over 500HP while addressing known low fuel starvation issues by returning the fuel directly into the fuel bowl. The...
hurricaneperformance.ca
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
This Hurricane fuel pump and pressure regulator kit is needed for tunes over 300HP on the Sidewinder-Thundercat 998. This kit is designed to fit like OEM and will supply fuel for over 500HP while addressing known low fuel starvation issues by returning the fuel directly into the fuel bowl. The...hurricaneperformance.ca
Really doesn't say that in the advertising.
Shows a picture of the pump, regulator and an elbow. If you put a description of what the elbow does and what fuel pressure the regulator is set at might help.
Due to the fact that its not advertised many may purchase elsewhere.
I did....
Kuzzy
- Dec 6, 2020
- saskatchewan
- 2020 yamaha sidewinder xtx se
2022 STX GT
2017 King Cat M9000
I have to agree, not with the pump in particular, but just a general no description from most of the vendors on most products. It is frustrating, it's like vendors are trying to cull the herd before they can pull out thier credit card.Really doesn't say that in the advertising.
I did....
Nothing against hurricane, I literally just got my order from him, but I find myself shopping at all vendors because of poor descriptions, instead of a one shop stop.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yea how about some detailed instructions from all vendors on some of this stuff. Not saying anyone in particular but some of these mods and product need way more details.
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
2012 Apex xtx
That's why I just did the return myself and bought a pump. Just trying to see if a fuel regulator is nessasary. I'm running Dave's 240/270/300 pm ss flashes and wanted to make sure I wasn't running out of fuel on the larger tune in cold weather.Really doesn't say that in the advertising.
I did....
HURRICANE
We’ve listened to some constructive feedback and responded with a better description for the hurricane fuel supply kit
Kuzzy
- Dec 6, 2020
- saskatchewan
2022 STX GT
2017 King Cat M9000
Thanks Dave! I've always said, it's how people deal with criticism/ego that tells me what kind of person they are.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
If you look at my signature I run Hurricane products on my sidewinder and his products work very well.
I have been running Hurricane tunes since the fall of 2017.
If you saw the add before Dave changed it you would understand why I posted what I did.
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Would this be plug and play or more involved to it?90 percent are not genuine. Also there’s two versions of the 255 pump, you want the high pressure version.
https://walbrofuelpumps.com/255lph-walbro-gss342-intank-fuel-pump.html
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Installing a bigger /different fuel pump is pretty straight forward once you open up/remove fuel slipper. One thing Clutchmaster pointed out awhile back and others is the stock wiring and fuel relay/power supply is not up to the task with bigger pumps. Its possible to do this yourself but the link below is a option.. If you read his description of the product it explains what can happen on bigger tunes and stock wiring and small relay. I posted it in a earlier post as DMC is using this harness. I will be also. DIY is probably a lot cheaper.Would this be plug and play or more involved to it?
www.ebay.com
max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
just installed and chked voltage,,,, is way higher than factory soo should wrk perfect. really nice piece.
