budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 Apex GT 40th, 2008 nytro rtx, 2005 RS Vector MTN turbo, 2001 VMAX 600
No studs, last year I hated this track in relation to how the sled pulled in stock form power and clutching, tried Ulmer’s primary clutch kit and lost top end by 5 to 6 km/hr verses the stock setup. The track wouldn’t hook up and really sucked on top end also. This year with the added power and more snow where I’ve been riding the track works very well and performance of sled is incredible.Maybe its the bigger lug track that helps with hook up,are you studded to?
Just FYI my rear suspension is still set how it came from dealer .
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Are you still on ulmers clutch kit? What did his kit consist of for a stocker,was it stm weights a pink primary spring,any helix change and secondary spring from allen to go along with primary clutch?No studs, last year I hated this track in relation to how the sled pulled in stock form power and clutching, tried Ulmer’s primary clutch kit and lost top end by 5 to 6 km/hr verses the stock setup. The track wouldn’t hook up and really sucked on top end also. This year with the added power and more snow where I’ve been riding the track works very well and performance of sled is incredible.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Quick question for you Ulmer clutch kit guys.....
Are the weights 60YS? Or are they the 60Y?
Im not sure if Allen sets these up so you are not sure what weights they actually are, but I have the STM 60YS weights, which weigh in at 63g(62.9) and I believe the 60Y are the trail weights, which weigh in at 60g.
The YS are entitled "turbo" weights on Supreme tool site.
Mine say 60YS on side of them, so can you guys just let me know which ones are in Allens kit.
I did not realize the YS profile is darn near identical to stock Winder weights.(see pic 1)
Pics below of mine
thx
Dan
Pics below of mine
thx
Dan
- Sauk Prairie, WI
- www.ty4stroke.com
Dan, mine are YS. Loaded they are 84 grams
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Thanks brother!Dan, mine are YS
Just to clarify, yours came in a Sidewinder Ulmer kit?
Just want to be certain as Im using Allens chart as a loose guide to my initial setup....I am using several different other components, so that is why I say "loose".
thnx
Dan
- Sauk Prairie, WI
- www.ty4stroke.com
Dan, mine are YS
correct, came with Allens kit purpose built for tuned SW'sThanks brother!
thnx
Dan
budman 1000
- Jan 22, 2010
- Saskatchewan
Mine also are the 60YS sold by Ulmer’s as the Sidewinder clutch kit.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I'm running 85 grams in my 60ys now with the 35/39. Still overeving and need to add more weight. Now that I seem to have solved my belt issue thanks to Mike I'll concentrate on pulling the revs down. I must say PT CAI tune is a blast on the trail and keeps pulling and pulling.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Thanks everyone much apprec....
Im going to pull my 33/35 w/orange TP spring out of sec.....while this sec setup really helped a ton with bottom snap ect, on my STOCKER.....I want to throw more at it now that I am tuned with a quick spool map.
Will update as I begin to test -
PRIMARY: 60YS STM's/Glide Washers/Dalton Blue(53/133kg)
SECONDARY: Not quite decided on Helix yet/ Dalton Orange(31/52kg)
Dan
Dan
