Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
When you are removing cover, for whatever work you're doing. Are you replacing the cover gasket? If you decide to use the old gasket are you reapplying yamabond to cover side when reinstalling?
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Rubber o-ring, I've done lots without replacing or using any Yamabond.
Doc Harley
- Oct 17, 2016
- Here & there
My particular valve cover gasket is similar to the chaincase style, if it were a true o-ring style id probably have better luck. Lol!Rubber o-ring, I've done lots without replacing or using any Yamabond.
Once i removed coils, plugs and hold down bolts, i released coolant tank above turbo to ad in clearance. It took a bit of work to remove valve cover.
There must be something ive overlooked, as I'm having a go of it, cover is making contact with cam hold downs. Can't seem to get cover back on, in a straight forward easy way.
0degC
- Jun 5, 2009
- Sudbury, Ontario
- 2023 SRX, 2017 XF 9000
Always harder to get back on. Ideally need to take more stuff off and out of the way to get cover on. We are always looking for the easy way and turns out to be the hard way lol.My particular valve cover gasket is similar to the chaincase style, if it were a true o-ring style id probably have better luck. Lol!
Doc Harley
- Oct 17, 2016
- Here & there
I should have know, it was going way too easy. Lol! All buttoned up and ready to ride.Always harder to get back on. Ideally need to take more stuff off and out of the way to get cover on. We are always looking for the easy way and turns out to be the hard way lol.
