JAM_MAN
- Oct 30, 2009
As an owner of a 2016 Viper LTX LE, without studs, what are recommendations to replace ski carbides? I am still running with ones that came stock, basically have limited control and a significant push in the corners. My dealer told me that from factory sled comes with 2" carbides on one side and nothing on the other - I have not validated this yet, but would not be surprised given handling characteristics. Recommendations?
hognit09
- Mar 7, 2010
- beaver dam, wi.
- 2016 viper ltx le,2016 viper ltx dx
I went with 6"stud boy shaper bar, 4 of them turns really good
monte1214
- Apr 20, 2005
- Durham Region, ON
- www.portperrysnowmobileclub.com
- 2017 Sidewinder LTX-SE
I'm an aggressive trail rider, and I put these on 300kms (180miles) ago.
I'm very happy with them.
https://www.qualipieces.com/y08-352-06/top-gold-hc-carbide-runners
tnc110
- Jan 5, 2015
- Sidewinder BTX SE, SRXs
How much did steering effort have to increase?
SnoUSA
- Dec 3, 2005
- Eagle River, WI
- www.snowmobileusa.com
- 2016 Yamaha SR Viper RTX
I did just the shaper bars without studs and it still pushed so I ended up studding and working on the rear suspension. Here is what I did and it handles like its on rails. 6" shaper bar inside 4" shaper bar outside, 90 Woodys megabite 1.375 studs, front limiter moved to 3rd hole, front track shock spring 15.8 mm spacing from bottom threads to bottom of lock collar and rear coupler blocks set on 3. Has very little ski lift and minimal high siding. Everything is adjustable, you just have to find the right setup for your style of riding.
- 35K
