bot
- Aug 17, 2016
- ottawa
- 2014 viper long track
The wife's 2014 viper..I was playing around with 2weeks ago, in heated garage getting the hang of how to changing the belt,.... Same belt went back on it 1000km on it....now when it sits at idel it wants to creep ahead like it's driving itself lol,,it ran mint before, I was pushing on the helix 2 weeks ago...now it wants to creep ahead all the time...any thoughts? the yams dealer said gonna have to shim the secondary ,.but I find that hard to bealeave cause it was working good before I pushed the helix in doing the belt things ..thanks
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Have you ran it outside since the belt reinstall? You have to run the sled through a range of RPM's under a load to properly set the belt deflection. If that doesn't do it then you will have to remove shims behind the three bolts on the back of the secondary clutch. Yamaha sells 1 mm and .5 mm shims so you can remove 1/2 mm for adjustment.
Also check the clutch springs to make sure one of them didn't brake.
Clamb
- Oct 2, 2016
- Peoria IL
- 02 Sx viper Er 15 sr viper xtx
- Peoria il
When you put a new belt on or mess with the belt did you pull it backwards toward the secondary to bring it up all the way sounds like that’s your problem
bot
- Aug 17, 2016
- ottawa
Shea put 1000km on ot since tuesday
.. and runs good..just wants to creep ahead when started at a gas station or parking lot.where theres not much snow to slow it down... did it on a groomed trail aswell...i ll check the springs tonite when i get back from doing the bon echo loop.. but everything seems fine... the top of belt is dead flush with top of secondary
.same as my 15 viper...everythimg seems to be the same as mine...just hers creeps ahead
viper strike
- Dec 22, 2016
- belle plaine mn
- 2015 yamaha sr viper ltx dx
Belt deflection is to tight
Studroes144
Check your primary clutch, if the belt is flush in the secondary then it's not too tight. Look for a broken primary spring first.
bot
- Aug 17, 2016
- ottawa
Got home today from lastweeks trip...get the clutchs on her viper...primary spring is broken.. amazed she rode 1000km last week with it broken... never in my life have a had a sled break a primary spring... never even thought to look the springs over...
bot
- Aug 17, 2016
- ottawa
Think that would cause any damage ..her riding it like that for 1000km... and was running fine.. other then creeping ahead
..deff a broke spring tho
Yea was a bad batch of them 14-early 15. Lots of broken ones. Dont hear about it much anymore.Got home today from lastweeks trip...get the clutchs on her viper...primary spring is broken.. amazed she rode 1000km last week with it broken... never in my life have a had a sled break a primary spring... never even thought to look the springs over...
Not unless end of it gouged clutch all up.Think that would cause any damage ..her riding it like that for 1000km... and was running fine.. other then creeping ahead
bot
- Aug 17, 2016
- ottawa
Tore it apart..it looks alrite...i ll get new spring tomoro..
bot
- Aug 17, 2016
- ottawa
Thxs everyone and thxs studroes
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
I'd order Schmidt bros comfort clutch kit for it. It comes with the primary spring and smaller rollers for lower engagement. She'll like the lower engagement and it shouldn't brake a spring again.
