fx-treme
- Jan 7, 2005
- 2014 SR VIPER LTX SE
has anyone had paint chipping from the main mounting bracket that the brace from the stirring column mounts to. It is on top of the tunnel, under the seat right were the gas tank is formed in for it. On mine both sides are bubbling and chipping right off. just going to use some white touch up paint but it does look awful.
RacinJason15
- Jan 23, 2008
- Comstock Park, MI
- 17' Yamaha Sidewinder LTX DX
- Comstock Park
Both of my lower a arms by the sway bar links are completely rusted and the "powder coat" is gone. 4200 miles
fx-treme
- Jan 7, 2005
some pics of my paint chipping and bubbling. seems excessive for 1400 miles ???
Sharkboyz Plungerz
- Dec 7, 2014
- 2015 Viper RTX SE
Did you take it to dealer to look at it? Warranty?some pics of my paint chipping and bubbling. seems excessive for 1400 miles ???
View attachment 107299 View attachment 107300 View attachment 107301 View attachment 107302 View attachment 107303 View attachment 107304
That looks like corrosion due to improper metal prep before paint OR allowing salt or moisture to be in constant contact.
fx-treme
- Jan 7, 2005
Not yet but I plan to. Not sure if warranty would cover this but hoping so. The tunnel was iced up a couple rides ago after it melted off I notices the chips. Its always kept in a dry garage and cleaned after every ride. The metal that's chipping looks like cast pieces and the paint is not adhering.Did you take it to dealer to look at it? Warranty?
That's not chipping it's corrosion beneath the paint.
fx-treme
- Jan 7, 2005
I will tell the dealer this. That would be a factory defect. Thank you.That's not chipping it's corrosion beneath the paint.
My Support bracket under seat chipped exactly like that but no bubbling. Touched it up a bit but you can see. Couple coats of the girls white fingernail polish works well. Just one coat in pic. FX like said the bubbling is corrosion or contamination. Will have to sand that off before painting.I will tell the dealer this. That would be a factory defect. Thank you.
