Andrew Mercer
- Dec 17, 2016
- Sussex
- 2014 sr viper ltx se
I have a 2014 sr viper ltx se and it will not start. I started it one month ago after sitting all summer and it started right up. Last weekend went to start it and the battery was gone. (Bad cell) I replaced the battery and still will not start! The starter engages and will go for a short time until the battery dies. Any help with this would be wonderful.
InRBigness
- Apr 10, 2014
- winnipeg, manitoba
Start with the basics. If it ran just a while ago the answer will be very simple. Gas, air spark. Did you undo any wires? Kill switch off? Just spit balling here.
Andrew Mercer
- Dec 17, 2016
- Sussex
Filled the gas tank. Pump runs kill switches are good. No idea what to look at next. Does anyone know what the lastest recall on the vipers are?
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Dumb question! But is the kill switch off on the bars! It happened to me once, it still cranks over but won't run.
Andrew Mercer
- Dec 17, 2016
- Sussex
No I made sure to check that. The fuel pump won't run with the kill switch on.
Hammer 1
Sounds like the battery could be on it's way out. Hook into a car charger or booster pack and try.
Vilas
- Sep 6, 2014
- Urbana, Illinois
- 2014 Viper xtx, Thunder products clutch kit
Do you have a trickle charger to leave it on over night? i suggest pulling the plugs out and making sure they aren't fouled. Is there any chance mice could have gotten in there and chewed up anything? That's happened to a lot of people over the years.
Andrew Mercer
- Dec 17, 2016
- Sussex
Finally got it running the fuel line must have been air locked. Right at the fuel rail. I unhooked the fuel line along with many other things and that's what I'm going with.
hellflyer
- Dec 2, 2008
That's good to hear!
- 15K
