Voltage regulator
super1c
Moderator
Age
54
Freeland - Otsego lake, MI
22 sidewinder LTX-LE
Hi guys. Think we have a voltage regulator problem on a 2020 sidewinder. Battery won’t charge, lights flicker ect. Will start with jump pack but runs rough. For the life of me I cannot find the voltage regulator. Do I have to remove exhaust to see it? Thanks! Chris
Replace the battery. Jump pack will start the sled but if voltage is low the sled will run rough. When you shut the sled off will it start on it's own without the pack?
No it will not. Had to jump it all day. But I did think battery also but it’s pretty new. But they can fail without reason for sure.
Are all cables and connections tight? I.e. connections at battery and starter solenoid at battery, connections at starter (both negative and positive)? They often are loose.
