Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Looking into a Walbro gss342 that Walbro sells for $107us. Amazon has what is described as same for $63us.
It's tough to know what's real and what's a copy, but $40 is $40.
Anyone know where to get one at a decent price?
earthling
First thing I would say is don't shop on your phone. The mobile interfaces to many websites have to hide details in order to fit everything on the mobile screen. Its the details that give away whether something is fake or not. Having said that, there are several walbro GSS342 pumps on Amazon for between 69 and 73 dollars from seemingly reputable stores. Its Amazon, if its not the real thing, send it back.
Doc Harley
- Oct 17, 2016
- Here & there
So after much review, Walbro has rebranded to T1, which is the parent company. I can safely assume the $25 version is the knockoffs. $60++ for just the jump is about right.First thing I would say is don't shop on your phone. The mobile interfaces to many websites have to hide details in order to fit everything on the mobile screen. Its the details that give away whether something is fake or not. Having said that, there are several walbro GSS342 pumps on Amazon for between 69 and 73 dollars from seemingly reputable stores. Its Amazon, if its not the real thing, send it back.
Watched too many reviews where people are disappointed with it. Either too loud, failure rate, etc. Lol.
Makes one wonder if it should the factory pump should even be changed out just yet.
So, I'll do the harness & return line. And wait till I grow into Max20 +/-
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
Walbro direct Number 1(989) 872-2131 they can help you in the right direction… Believe they are in Cass City, Michigan and have been for many years….
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
You will need to cut one of the connectors off and crimp on a new female connector as stock uses a small a large do polarity isn’t mixed up, these do not they are same connector. And after taking this out and doing the swap I’m nervous to start it for some reason. Lol
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Walbro GSS342 Intank Fuel Pump 255LPH High Pressure (Universal)
Walbro Part Number: GSS342Type: Universal Intank Fuel PumpFuel: GasHorsepower: 500HP+Flow Rate: 255LPH Caution: Extremely High Counterfeit Rate - Buy from an Authorized Dealer Only
walbrofuelpumps.com
This is exactly what I have and I have no desire to roll the dice on fakes.. Buy from a reputable genuine parts store.. This is a very important part for tunes sleds..Looking into a Walbro gss342 that Walbro sells for $107us. Amazon has what is described as same for $63us.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Call Steve at full throttle speed, I believe he sells them., and hydro mats for tank
Doc Harley
- Oct 17, 2016
- Here & there
Thanks for the tip.Call Steve at full throttle speed, I believe he sells them., and hydro mats for tank
Doc Harley
- Oct 17, 2016
- Here & there
It's come to my attention that when going to bigger tunes and utilizing MS19/20, one could add a bigger pump in keeping deto at bay.
So instead of needing 100 octane one could utilize 93 octane and a small splash of boostane, to keep things in check.
Sure would make life a whole lot easier.
Any truth to those words?
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
Yes, I have always run 93 when I was running MS19/20 with a big pump.It's come to my attention that when going to bigger tunes and utilizing MS19/20, one could add a bigger pump in keeping deto at bay.
Doc Harley
- Oct 17, 2016
- Here & there
Thanks Slow998.... I'll be heading that direction mid-year if everything goes right.Yes, I have always run 93 when I was running MS19/20 with a big pump.
What was your choice for intercoolers?
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
I'm still running the stock coolerThanks Slow998.... I'll be heading that direction mid-year if everything goes right.
Doc Harley
- Oct 17, 2016
- Here & there
Mostly radar stuff, any long stretches?I'm still running the stock cooler
Slow998
- Jan 11, 2021
- Maine
- 2021 Thundercat
- Maine
Ya, we have a few straight stretches that 2 miles long. I make some long pulls and IATs become an issue... but I don't race all that often on the railroad bed anymore.Mostly radar stuff, any long stretches?
Turboflash
- Mar 18, 2019
- Southern MN
There's allot more to keeping deto at bay than just octane. Every "tune" starting at stock level and going on up needs certain things to prevent deto. First, the map has to be right (usually developed from lots of hours on dyno). Right means right boost, right timing, right injectors (capacity), right injector pulse, right engine cooling, right inter-cooler,etc. One can make up for too low octane (to a certain point) by richer fuel mixture. Or, running Boostane. As far as bigger pump preventing deto, that is not necessarily true if there are other issues like boost leaks, engine with too high compression, too much timing, injectors too small, coolant temps too high, IAT too high, etc. Every tune is engineered to run at a certain fuel pressure (stock 998s = 43 psi, key on engine not running). As long as the pump can keep the fuel pressure rail at the right psi, assuming everything else is right, then all should be ok. However if the fuel pump can't keep up with demand, then the AF ratio will get leaner and deto will likely result. No doubt bigger tunes need more fuel delivery. I've always heard that stock fuel pump is ok up to about 270HP. IDK. Keep in mind, the 998 turbo system is a boost reference system meaning that fuel pressure goes up and down like boost does. For every 1 lb of boost added, fuel pressure will also increase 1 lb. At some point, the injectors aren't big enough (volume-wise) to delivery enough fuel within the allowable pulse width the ECU has to work with.It's come to my attention that when going to bigger tunes and utilizing MS19/20, one could add a bigger pump in keeping deto at bay.
When in doubt, a bigger fuel pump is a good idea IMO. Fuel not needed by the injectors is just returned to tank via the return line. Raising octane via Boostane IMO is also not a bad idea. Raising octane even 2-3 points (from pump 91 or more) does help prevent deto. Lots of guys who data log can see the difference Boostane makes.
Not sure about TD and Hurricane's biggest pump tunes, but for my Stage 4 PEFI tune (330 HP), I have to run fuel pressure at 58 psi (key on engine not running) in order for stock injectors to flow enough to keep engine fed adequately. So an adjustable FPR is also handy. You can richen whole fuel map by just increasing FP a few pounds.
