jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Many springs available from vendors. I think it important to remember here that it’s about the degree of twist with other factors also. Helix angle, weight profile, studs #, belt brand. A lot of variable but the most important is that you test and temp check the secondary while twisting/increasing degrees on the secondary spring. You want it just enough side pressure to hold the belt from slipping. No matter the spring brand THIS is and most important. That being said I do like the TP orange. I also have a Dalton black orange V2. Great spring also.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
I would add to the variable list track lug and length. Also snow type. And type of riding. Not one set up is the magic set up
I’ve found it the more power the fussier the setup
Lots of smiles though
ranger1
Ya'll talked me into going with the TP Orange secondary spring....does anyone know where I can buy one in Canada as it will cost me around $120 after shipping and exchange from TP and thats not including brokerage fees ( if they apply)
Thans for any info !!!
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Have you reached out to tim or terry at thunder products to see if they have stocking dealers in canada?fyi they are very very busy so it may be a minute to get a response but they are top notch peopleYa'll talked me into going with the TP Orange secondary spring....does anyone know where I can buy one in Canada as it will cost me around $120 after shipping and exchange from TP and thats not including brokerage fees ( if they apply)Thans for any info !!!
ranger1
Thanks Dan but I just ended up ordering the black/orange Dalton spring. I hope it is as good . Thanks just the sameHave you reached out to tim or terry at thunder products to see if they have stocking dealers in canada?fyi they are very very busy so it may be a minute to get a response but they are top notch people
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Its as good.Thanks Dan but I just ended up ordering the black/orange Dalton spring. I hope it is as good . Thanks just the same![]()
- 13K
- 9K
- 41K
- 26K
