Turboflash
- Mar 18, 2019
- Southern MN
Yup. It's their way of not having to force one to buy bigger injectors (adding substantial $$ to kit price). If that tune used stock fuel pressure, I'm sure their kit would have to include bigger injectors. This tune is a multimap so they had to re-calibrate all the other lower HP tunes for the 58 psi 4-bar too, even though if you buy the next lower multimap (PEFI Stage 3R) they are all 3-bar maps. Only when you go to Stage 4 does it change to 4-bar. They have a Stage 5 too that does have bigger injectors. Not sure if it's 3-bar or 4-bar. Hard to believe these are pump gas tunes?!! They'd have to show me.That kit runs a lot of fuel pressure considering stock is 43.
- 18 PSI = 300 HP on pump gas
- 20 PSI = 325 HP on pump gas
- 22 PSI = 350 HP on pump gas
STAGE 5 - 998 TURBO
Precision EFI 998T Turbo Upgrade The Precision EFI Stage 5 is the world's highest-performing kit designed for trail riding. It delivers phenomenal torque and instant throttle response with no turbo lag. Ultra-efficient and so fast that it makes you feel invincible. Imagine what it feels like...
precisionefi.com
Turboflash
- Mar 18, 2019
- Southern MN
That tells you that stock injectors will not flow enough at 43 psi within the pulse width they have to work with. Only choice to not have to get bigger injectors is more FP.That kit runs a lot of fuel pressure considering stock is 43.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
The whole conversation has me wondering....
1) I'm curious to know the duty cycle on these injectors at a given rate (horsepower). they do have a rating, I never hear anybody speak of it.
2) at some point the pressure against the pindle causes the injector to lock up. Does anyone know what that is?
Everything in this universe is made to fail...
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Best fuel pump upgrade assembly on the market
https://shop.ulmerracing.com/Fuel-P...&browse=-73647&shopBy=-26776&catalogId=-11683
Turboflash
- Mar 18, 2019
- Southern MN
I completely agree. And, I think allot know PEFI hardware is best in industry.Best fuel pump upgrade assembly on the market
I have allot of PEFI hardware. All of it is just absolute jewelry.
Most know it is also high end expensive but we all know we get what we pay for.
The only thing I changed on PEFI fuel pump upgrade is the pickup strainer.
I didn't reuse stock pickup strainer as I thought it might be restrictive with bigger pump. I changed to a bigger, better fitting aftermarket strainer that fits the new larger pump better and allows better inflow to pump.
REDLINE 1
- Sep 20, 2019
- ROUND LAKE IL
- 2018 TCAT
I see PEFI is having a 20% off Black Friday sale right nowI completely agree. And, I think allot know PEFI hardware is best in industry.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
22 psi at 350 hp on pump gas ? Would love to to see that on an independent dyno.Yup. It's their way of not having to force one to buy bigger injectors (adding substantial $$ to kit price). If that tune used stock fuel pressure, I'm sure their kit would have to include bigger injectors. This tune is a multimap so they had to re-calibrate all the other lower HP tunes for the 58 psi 4-bar too, even though if you buy the next lower multimap (PEFI Stage 3R) they are all 3-bar maps. Only when you go to Stage 4 does it change to 4-bar. They have a Stage 5 too that does have bigger injectors. Not sure if it's 3-bar or 4-bar. Hard to believe these are pump gas tunes?!! They'd have to show me.
STAGE 5 - 998 TURBO
Precision EFI 998T Turbo Upgrade The Precision EFI Stage 5 is the world's highest-performing kit designed for trail riding. It delivers phenomenal torque and instant throttle response with no turbo lag. Ultra-efficient and so fast that it makes you feel invincible. Imagine what it feels like...precisionefi.com
stgdz
- Mar 27, 2021
- Buffalo MN
After seeing the hoops you guys jump through the hoops I think I will just stay between 240 and 270 on pump gas. I've cleaned the I hectors, plumbed a return line to basket, and the pump relay hooked to the battery to keep everything alive.
Doc Harley
- Oct 17, 2016
- Here & there
Yeah, I'm getting ready to throw up. Lol. Guys are definitely going off the deep end.After seeing the hoops you guys jump through the hoops I think I will just stay between 240 and 270 on pump gas. I've cleaned the I hectors, plumbed a return line to basket, and the pump relay hooked to the battery to keep everything alive.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Wow PEFI runs big fuel pressure, I run 47 PSI key on with stock injectors at 22-23 lbs of boost and my closed loop pulls fuel most of the time.
stgdz
- Mar 27, 2021
- Buffalo MN
Don't get me wrong there is a lot of intelligence and strategies for keeping the motor alive. But I wonder how close to the sun people are flying. I tend to be conservative with whatever I build.Yeah, I'm getting ready to throw up. Lol. Guys are definitely going off the deep end.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Precision stage 5 is a turbo upgrade so thats why they are at 350hp at 22 psi. I agree with turboflash on the quality of their hardware........you dont even want to install any of it because its so nice lol, great quality and perfect fitment. You are getting what you pay for, pay once and cry once.
Doc Harley
- Oct 17, 2016
- Here & there
Hahaha....I'm with ya.They aren't pushing the boundaries of the motor. They're pushing the boundaries of what's necessary.Don't get me wrong there is a lot of intelligence and strategies for keeping the motor alive. But I wonder how close to the sun people are flying. I tend to be conservative with whatever I build.
Like you, I like to stay within a level that can be justified. Which I call pump gas friendly. I don't even like adding boostane.
With dragy, I'll do some back to back between sm & pm tunes, clutch accordingly and see for myself.
If the PM tunes can't achieve a desired result over sm tunes, what's the point?
Anyone know what fuel pump Hurricane is using in their fuel upgrade kit?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
That makes more sense with a bigger turbo, I ran the turbo technics turbo and ran all day long at 350 on pump gasPrecision stage 5 is a turbo upgrade so thats why they are at 350hp at 22 psi. I agree with turboflash on the quality of their hardware........you dont even want to install any of it because its so nice lol, great quality and perfect fitment. You are getting what you pay for, pay once and cry once.
