pat the rat
finally found out why i had a warped rotor on the grizz,when it was new,i decided to see if the 660 rims fits on the 700,they went on no problem,installed nuts and tightened all 4 wheels with impact,dropped the bike to the ground ,when i went to take off,no go,just like all 4 wheels were seized,turns out that i needed spacers,most people know about the wheels not fitting but i never thought that was the reason my rotors were warped,same happened to the yammi mechanic here in town,he warped them also,so make sure you have minimum 1'' spacers
Also be careful with the impact on over tightening.
pat the rat
yep,youre right,i set my impact a little slower and all is goodMrSled said:Also be careful with the impact on over tightening.
sx7er
- Jan 2, 2008
you mean the mechanic's CO-OP student.... hahaha....
pat the rat
no,the licensed yammi mechanic,and a good 1 at that,its just 1 of those things you dont notice the first time,it fits so good but the rotor is just a tad too big
clutch
Pat, that is how I learned that the wheels were different. The rears cleared on mine but the fronts were litteraly a no go.
- 40K
