Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
Like many liquid cooled units air is extremely hard to remove from this system. By taking a funnel and sealing it to the system I could run the sled and see air come out over a period of time. The bleeder on the right side of the sled also will burp air. In our work area we hang the sled from the spindles and the back bumper. Lowering the rear and raising multiple times removes allot. Any air is the enemy of a pump.
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
Awesome. Thanks for finding that.
stgdz
- Mar 27, 2021
- Buffalo MN
Wouldn't we see a lot of waverunner and yxz failures then?It wouldn't surprise me at all if the impeller manufacturing has been outsourced by Yamaha to China since 2017 and are using inferior materials.
twyztid
- Feb 14, 2011
- Middleville, MI
- 2025 Sidewinder LTX LE EPS
2025 Sidewinder LTX LE EPS #2
2017 Sidewinder LTX SE
2012 Apex XTX
2012 RS Vector LTX
- Middleville, MI
There ARE a lot of failures in the SXS's. That is WHY Dasa Racing is making the billet impellers. It isn't because of failures in the sleds. It just happens that the engine is the same so the water pump that they make works for our sleds as well.
Simplespeed
- Jan 8, 2022
- 1191 Sauk Lane , Saginaw, Mi. 48638
- 2006 Apex , 2017 Sidewinder LTX -LE
The question was … Lol. Is the cooling of the turbo causing the cavitation in the system thats taking out the water pump propeller ??? The loose hose clamps should be leaking antifreeze if system is under pressure at all ?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Since looking into this a bit, it sort of bugs me that the gurgle is there at all. gurgle implies air? not sure what else causes the noise. The convection (thermosiphon) used to cool the turbo should not be 'creating' air, as I suspect that the coolant should be below its boiling point unless it is flash boiling as it touches the hot impeller housing or wherever it flows. If this is the case, the only cure is to not use the convection cooling? (question not a statement) and/or add a secondary circulation pump on a timer, or as some have suggested, add some sort of auto-bleed valve to the system. dunno. A properly working thermosiphon should be circulating pure fluid and probably wouldn't make any noise.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The gurgle is boiling of the coolant coming out of the turbo from the extreme heat. Evidently people just shut them down after a hard run rather then letting them cool down before shutting off....
Turbo on any engine should be run easy and idled before shutting it off, not only does it preventing the oil from coking and taking the turbo out over time, it also prevents the coolant in the turbo from boiling and making the gurgling noises. Gurgling is not a good thing, it tells you you didn't let it cool down enough prior to shutting it down. Its simple turbo 101.
Simplespeed
- Jan 8, 2022
I agree and it is just more likely that the cavitation and Air is caused from cooling the turbo and forever reason the air is getting in ( we know this should not be happening ) but the system has a flaw.. Now where is it and why???
Simplespeed
- Jan 8, 2022
Ok Mike, thats kind of what I was thinking also ..The gurgle is boiling of the coolant coming out of the turbo from the extreme heat. Evidently people just shut them down after a hard run rather then letting them cool down before shutting off....
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
What makes u think the system has a flaw ?
stgdz
- Mar 27, 2021
- Buffalo MN
I thought Yamaha had a feature on the 998 that made a turbo timer unnecessary or the technique of running a turbo timer without one.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
Thinking this through and I agree with you WRT cooling the turbo post run.
But.. This was by design. Yamaha actually brags about the vapor tank/convection cooling aspect of the system
I guess I have to go out in the garage and look at the actual system, the parts fiche doesn't really tell the story (at least so I understand it).
Simplespeed
- Jan 8, 2022
Maybe flaw would be wrong description, how about we refer to it as a design that is need of improvements to again prevent water pump problems..What makes u think the system has a flaw ?
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
To evaluate it as a flaw we need to understand the byproduct (measure the outcome). Ignoring the water pump for a second, if we saw a lot of turbo failures I would say the design is flawed. To know how well it is working we would need to measure the system post shutdown for flow as well as input/output temperature on each side of the turbo. If it is indeed causing air to enter into the system then that is also a flaw. Right now the only way we know it is working is the gurgling which implies that the coolant is boiling and maybe that is all in how the vapor tank works (which I see in the fiche but have not looked at).
- 9K
