max rolph
- Feb 10, 2021
- horse shoe valley
- 998 turbo
i put the dasa racing impeller in this summer just as aprecaustion, very easy to do, remove clutchs and torgue link. it took @1.5 hours. then bleeding system takes longer, i used a CLEAN shop vac to suck out antifreeze... makes jobe nice n clean.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I might do this in the off season.. I think its good insurance.i put the dasa racing impeller in this summer just as aprecaustion, very easy to do, remove clutchs and torgue link. it took @1.5 hours. then bleeding system takes longer, i used a CLEAN shop vac to suck out antifreeze... makes jobe nice n clean.
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
Great. idea.i put the dasa racing impeller in this summer just as aprecaustion, very easy to do, remove clutchs and torgue link. it took @1.5 hours. then bleeding system takes longer, i used a CLEAN shop vac to suck out antifreeze... makes jobe nice n clean.
stgdz
- Mar 27, 2021
- Buffalo MN
So did you guys do the jackshaft bearings while you were in there?
Cause it's just gonna knaw at you.....
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
I found a water pump impeller and shaft I had from a Nytro. After checking part numbers it seems the Nytro and Sidewinder have the same parts. I don’t seem to hear much about failures on the Nytros.
Spaceman
- Apr 20, 2017
- Ohio
- 18 Thundercat
Is it plastic? Mine was and a small overheat in warm conditions warped mine.I found a water pump impeller and shaft I had from a Nytro. After checking part numbers it seems the Nytro and Sidewinder have the same parts. I don’t seem to hear much about failures on the Nytros.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
Plastic.Is it plastic? Mine was and a small overheat in warm conditions warped mine.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
The Japan sleds use constant tension hose clamps and most dont leak.I found a water pump impeller and shaft I had from a Nytro. After checking part numbers it seems the Nytro and Sidewinder have the same parts. I don’t seem to hear much about failures on the Nytros.
The Cat hose clamps leak and coolant develops
Air pockets. When the impeller gets air pockets in it and the coolant rushing shocks the impeller and causes damage.
Make sure your coolant system is always at the full cold line and no leaks.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
That makes sense. I wonder if we could change over to constant tensions clamps.The Japan sleds use constant tension hose clamps and most dont leak.
Turboflash
- Mar 18, 2019
- Southern MN
Of course but just make sure they are high quality and hopefully stainless steel.That makes sense. I wonder if we could change over to constant tensions clamps.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
How do you tell TDC? I see 2 sets of marks on flywheel. Which one is TDC on #3. Trying to remove water pump.
no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
Just turn the engine clockwise on the MAG side and line up the indicator mark.... Just pop out the larger plug in the MAG cover.... Clockwise only on this side.... Sounds like you could be 180 degrees out
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
I’m lined up. There are 2 marks horizontal across flywheel connected by a line running horizontal. Then one more mark. After those. I’ve tried lining up with all three and no luck.
- 8K
