Gone Blue
- Oct 11, 2006
- Howell, Michigan
BombaPolaYama
April 14th - 185Km in Taylor's Brook area, NL - the main trail is surprisingly good for not being groomed - but the trail into the gorge is brutal - had to turn back. Topped 3000Km for the season; 15781 total..
April 15th - changing the coolant - PITA trying to get all the old stuff out.
April 16th - Installed a new starter relay. #3 on this sled including original - should be good for another 7000Km.
grossman
Finished installing reverse. Not sure why it wasn't standard on all models, but problem solved.
Also did my oil change while it was torn apart. I'm now down to 3 screws holding my right side cover on...
BombaPolaYama
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Unpacked my skid just in from Half-Baked Powdercoating!! WOO WOO New stuff!
IT'S SHINEY!
IT'S SHINEY!
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Rolled the sled down a hill. Busted the headlight, bent some metal and got some new cracks in the plastic. Another great day of riding.
rayone02
- Dec 3, 2010
- adrian, mi
- 2012 Apex 2012 nytro xtx 2006 attak
Just installed dupont hyfax and new shock from hygear. Also installed pionner wheel kit with new wheels.
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Changed the oil!
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Finally got around to installing my rear cooler today.
Job went great and while I had everything apart I decide to adjust my rear flap so that it angled back more and didn't get caught or hit the ground while unloading it from the trailer.
(Just drilled out the rivets that attached to the tunnel and bent it up and out in my vise instead of removing the flap rivets)
Does the rear flap play a part in directing snow up on the exchanger?
I have seen flaps angled back more than mine was so I am now curious if it is angled back too far?
(before and after pics below, plus new cooler)
(3rd pic is new flap location, 4th is old or stock location)
Dimebag
- Nov 3, 2009
- Norway, 68N
- www.ty4stroke.com
Switched the track from a backcountry with 9000 kms on it, to a brand new Backcountry Race with 0 kms on it
The rear cooler is a must. No more temp lights.
mcamzr
Irv said:Does the rear flap play a part in directing snow up on the exchanger?
It does, I put the extra long race flap on my rev that used to run with the temp gauge just above half way. With the flap it ran at 1/4 no matter what the conditions. Yours looks good though. I wouldn't think you would have any issue. And like you said, i too have seen people with their flaps pointed straight back.
And I moved my sled to sweep under it. Yea!
MT.man
Your snow flap angle looks just like Yamaha uses now. I dont think you will have any issues.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
mcamzr said:Irv said:Does the rear flap play a part in directing snow up on the exchanger?
Thanks mcamzr and Mt Man, that is good to know
