tonykof
05 Warrior/CPR turbo - 2554 w/headshim running 12lbs
17.5 pilots/2 1/4 turns on fuel screws
needles raised 1/red springs
132.5 mains
A/F reads as follows
idle 17-18+ (guage goes to --- over 18)
mid 13.6 -14.1
Full throttle 12.1 - 12.6
Okay, the sled seems to runs fine it just seems a little mushy just off idle. Doesn't pop or anything just seems a little mushy. Could just be because of the the .080 head shim too.. Once I get to about 2500 - 3500 rpm it gets back to 13.5 - 14 on the a/f guage.
Do you think it would be worth it for me to change the pilot jets from 17 to the next size of 20 w/screws at 2 ? Or am I being too picky and since it isn't popping or anything just drive it?? Geez I hate pulling these carbs...
Tony
132.5 mains
mid 13.6 -14.1
Tony
Skydog
Boy you lean! Get that WOT to 11.5 or so
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Ditto.
Have you synced your carbs lately? May help the low end some. Have you checked the float hight, they play a part at low end. Stock setting is 13 mm.
When everything is checked and adjusted and still lean off idle, go up to 20 pilots.
ProstockBenji
- Feb 24, 2005
- Leamington, Ontario
- www.doublediamondacres.com
put 20 pilots in it , possibly 135 mains and you will be in the ballpark !
- 12K
- 49K
