biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Ya, the Garmin 55, 57, 58, 65, 67, 68 all use a USB port on the back to connect to power. They do not have a docking port.
So you can get a RAM cradle for more solid mounting, but you will still be connecting that USB cord for juice. I could be wrong, but look at the lower edge, there should be electrical contacts. But we have a few of the 50 series in our group, and they are all USB powered.
lakercr
Tech Advisor
Last year I had my Montana mounted above the factory gauge, but just moved it to the bars (can't run short windshield with Garmin mounted above the gauge). Similar to others here, I bent up a piece of aluminum/drilled it for mounting. I didn't expect the cover to work, so wasn't as careful trimming it as I could have been. Turns out it will be OK, so ordered another and will make it pretty. Note that there isn't a lot of thread engagement with a ~3/16" plate under the bolts. I bought 4 new ones - M8 x 1.25 40mm I think it was.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Thank you, biffdotorg!
I haven't received my 57 yet. But spent some time looking for a power cradle with no luck. Now I know why. Lol!
It's all good. Going to mount it like I did my last one. Then either use 12volt on dash or power by the case. Which I already have in use for a heated bag to keep my phone warm & working.
I really like the look of the low mount.
rbell14
One Stop performance makes a nice bracket that mounts your nuvi (or another GPS) just above the gauges using the same OEM holes and screws on the top panel. I just use velcro on the back of the GPS to mount it and it has never come off in over 3,000 miles.
https://ty4stroke.com/threads/viper-garmin-nuvi-mount.138677/
https://ty4stroke.com/threads/nuvi-50-install-pics.136186/
biffdotorg
- Dec 2, 2008
- www.biff.org
- www.biff.org
I have a nuvi mounted on my daughters Viper. I rode it today and feel the mount is too flat. It's directly on top of the handlebar pad. I needs to be tilted back. I may have to look at your mounts a bit more and adjust. Thanks for sharing guys!
snoseeker
- Oct 9, 2005
- FARMINGTON MN
- just up dated to a 2017 sidewinder , 2011 xtx apex, 07 attack, 98 700 delux, 97 600 sx
- minnesota
actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Can anyone post more detail on the OSP no drill bracket ? I want to look at modeling something and 3D printing it.
WarriorDan
- Oct 30, 2003
- Bloomfield Hills, MI
- 2022 LT-X GT EPS
Good pictures on ospracingparts web site.
- 13K
