sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Like the title says where is the best place to mount the autotune? Haven't tore it apart yet, just been thinking about that now for a while and want a idea where to mount it. Thanks
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
it all depends on what exhaust system you are running, if it is under tunnel it is a bit of a chore, or even if you have skinz seat, i welded mine right into the mpi pipe, Right were the header connects with the tail pipe and it seems to be working great.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Sorry I mean the actual autotune box, I have a full hindle exhaust so it already has the bung welded on it.
sneakattak88
I put mine. On top of the plastic shroud for the rad with Velcro,
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
sneakattak88 said:I put mine. On top of the plastic shroud for the rad with Velcro,
The autotune? Or the PC5? I'm pretty sure the bung on the hindle exhaust is under the seat..........don't think it will reach the rad shroud.
sorenson1610 said:sneakattak88 said:I put mine. On top of the plastic shroud for the rad with Velcro,
The bung will be located about 2 inches in front of the muffler.
![](/styles/admin.gif)
![](/styles/vip.gif)
If you look further down in this post you will see mine.... this is on a Apex. so it may not help much.
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
Ok well I'll have to wait until I get it apart to see where a good spot would be..........does nobody have autotune on a nytro yet???????
yukon yamaha
- Jan 30, 2008
my auto tune box is under my seat held down with two zip ties and the pcv is on the rad plastic
sorenson1610
- Dec 11, 2007
- Rothschild,WI
- www.contrx.com
yukon yamaha said:my auto tune box is under my seat held down with two zip ties and the pcv is on the rad plastic
Thanks that's what I am looking for! The heat doesn't bother it there does it?
yukon yamaha
- Jan 30, 2008
I have a skinz seat, so i cant really be much help with that, but if it was a concern i would wrap it with heat foil?
- 9K
