Where do you have your "CO" set on your boosted ma
DaveB
Just wondering if there is a "general range" where everyone sets the CO. I understand the CO sets what would be the pilot circuit on a carbed machine and therefore really only affects idle and warm starting. My machine has always seemed a bit blubbery at idle (IE if you let it sit and idle for over a minute it will load up and sometimes stall)...no issues otherwise...so I checked the CO last night and it was at -10 on all cylinders. I tried 0 and it really didn't want to run, so I have it at -25 now and it seems better. Just wondering if this is a "normal setting".
I run mine at -20 with afr showing 13.0-13.5. May lower it more to bring it into low 14's or install a PC3 to tune rich low end.
On MCX turbos I run the C0 at -10 across, some sleds need to go lower to -15.
After -30 you are really not reducing fuel anymore. The curve is not linear, it drops, the reduction gets less the lower you go.
