hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Just sent you a PM.I am interested ,does it have the adapter kit installed? Does it come with mounting hardware?
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
I have a 129 SW with the UPT single. It works great.
You can just mount the extensions with the linq mounts directly to the tunnel but in my case i needed just a bit of height to clear the tail light and the UPT mounting system worked great.
If i had a 137 i would get the UPT double. My daughters Indy XC has the double and it is a great set up.
MS
MS
Todd Beenen
- Feb 16, 2020
- Michigan
- 2020 T-Cat
Got a double coming from Travis At BOP. He hooked me up.I have a 129 SW with the UPT single. It works great.
MS
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I have been using white out technologies link mounts for 6 winters. Works great.
Yamascotty
- Sep 28, 2021
- Duquette mn
- 2022 ltx GT eps
I added the
Kimpex Connect system
Stackable Roto Pax or Fuel Pax
Kimpex Adventure tunnel bag....
Or two stacked cans...
And
They are lockable
2022 LTX GT
And
They are lockable
2022 LTX GT
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
Any chance you could post up some pics of your set up on your sled? I've been interested in the Kimpex setup.I added the
And
They are lockable
2022 LTX GT
Yamascotty
- Sep 28, 2021
- Duquette mn
- 2022 ltx GT eps
Couldn’t get it done but lots on YouTubeAny chance you could post up some pics of your set up on your sled? I've been interested in the Kimpex setup.
SnowTrax Luke Lester did a good one.
I didn’t get my sled in time to use it so no long term review.
Seems good and comes with a template for drilling holes.
Works along with factory 20” tunnel bag.
I did a test to find out about how many days clothes it holds, 3 days worth depending of course on the individual
Yamascotty
- Sep 28, 2021
- Duquette mn
- 2022 ltx GT eps
I’m about 100 miles north of ya if you get up north sometime you can check it out personallyAny chance you could post up some pics of your set up on your sled? I've been interested in the Kimpex setup.
Duquette Mn
Next to the
Nemadji state forest
VX1R
- Sep 19, 2004
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1986 Inviter
Sounds good. I'll check it out.Couldn’t get it done but lots on YouTube
egstasea
- Dec 19, 2010
Yamascotty, do you need the KIMPEX CONNECT MOUNTING BASE GUIDE RAILS to make this system work?I’m about 100 miles north of ya if you get up north sometime you can check it out personally
Duquette Mn
Next to the
Yamascotty
- Sep 28, 2021
- Duquette mn
- 2022 ltx GT eps
NoYamascotty, do you need the KIMPEX CONNECT MOUNTING BASE GUIDE RAILS to make this system work?
Just a set of bases
One base piece is closed the other opens to accept bag or caddy
Look for the video by Luke Lester with SnowTrax TV
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Just a tip, when I in stalled mine I first tried the kimpex template on a piece of plywood and sure enough the spacing of the wholes was off, the fuel can or bag mounts will be a tad loose/wiggle around when locked down. I can’t remember off hand what I drilled mine at but can post the measurements once I measure mine.Any chance you could post up some pics of your set up on your sled? I've been interested in the Kimpex setup.
Yamascotty
- Sep 28, 2021
- Duquette mn
- 2022 ltx GT eps
Nice picturesJust a tip, when I in stalled mine I first tried the kimpex template on a piece of plywood and sure enough the spacing of the wholes was off, the fuel can or bag mounts will be a tad loose/wiggle around when locked down. I can’t remember off hand what I drilled mine at but can post the measurements once I measure mine.View attachment 168511View attachment 168512View attachment 168513View attachment 168510
I thought similar
Just cut to fit the paper template and secure to tunnel
Center punch marked locations for drilling
Attach mounting base
The reason I almost drilled my own holes was because the gas can holder has bolt holes for Polaris Ski Doo and Yamacat
Fool around till ya figure out which holes are right
It’ll fit great
VX1R
- Sep 19, 2004
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1986 Inviter
If anyone is looking to buy a Up North Technologies Double Mount Linq Bracket I have a spare brand new one still in the box that I'd let go for $150 shipped. It's the exact same bracket that's in the picture mounted to my wife's SideWinder. Shoot me a message if interested.
Hoosiersnow
- May 19, 2015
- Indiana
- 18 cat 600 137
Can you mount that dual mount far enough back on a 137 to keep the little OEM bag that fits under the rear edge of the seat? Looks like there isn't enough room.
