hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I had that same shock in my 16 viper le and now in my 20 sidewinder se. I found the low speed dampening to be to soft unless it was on #3 then it was to hard. I've revalved them and added DSC valves that can be adjusted low speed and hi speed. I just replaced my rubber bumper also but they seem good now
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
I have also gone thru 2 sets of rubbers and added the Star aluminum 5 position spring cam, set at 5 with shock at 2 ,and still bottoming , and not returning all the way up when nothing but a linq gas can on it.Center shock spring was too soft on mine. Put in the 160lb rate spring and adjusted to my liking.
I'm 215lbs and my sled hardly ever bottoms out. Rear springs set on soft.
I dont ditch bang. Just trail ride.
Are you saying at 240 dressed , I should have a stiffer center spring , rather than just more tension on the stock spring .
Is it likely my center spring has also lost its original tension ?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
My original center spring was a 110lb rate spring. Switched it to the 160lb rate spring and it worked for me. When the suspension couple's both the springs work together.
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
Where can you purchase this 160 lb in Ontario??
Also I read on here about running one torsion block on 1 & other on 2?? Will it cause any issues in suspension ?
Tomelongname
Stingray MODS Front Skid Shock Spring.
Spring designed by me and made for the front skid shock on Yamaha and Cat snowmobiles, manufactured in Texas from American steel. Replaces the Cat spring that allows too much weight on the skis. The Stingray MODS spring lightens the front and allows for weight transfer to the rear the chassis...
Upgraded 4 years ago to Bill's 160lb spring for my 2015 LTX DX and made a big difference. This summer installing the 8JX-G7473-00-00/8JX-G7474-00-00 torsion springs which I should have done a long time ago..
- 19K
