grizzlyokie
I am going to order some PIAA lighting,
PIAA, 004X Series, 35W=60W. Long Range.
Will the stater on my grizzly support these lights along with the headlamps I have now, or will I need to upgrade my stater also?
huntem
- Jul 8, 2006
Not sure about the PIAA specifically. I can share that I have installed the Warn front bumper and lights along with the Warn back up light. Because I have the winch cables on the battery. I wired a single 10 ga wire direct from the battery and wired the light wire harness to this wire. It makes for a easier hookup and disconnect if needed.
Getting back to your question. I do not see any light dimming to the headlights when I switch the Warn lights. I do have seperate switches for the front/back lights. I don't know if I would go with the 60amp lights. May be a bit for the system.
