- Nov 29, 2009
- sabattus, maine
Yeah, that's what I was getting at too, and the primary as well, seems there's differences there as wellI want to know if that new roller secondary will swap over? That would most defiantly be cool.
I tried to find info on what belt the Sidewinder will use thinking that would give some info but wasn't successful....didn't put a whole lot of time into it though...
Specs are showing only a longer belt noted.. so I would say a new belt is order.
They also said a different angle is used. Who wants to bet its 8DN length?
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Hopefully it'll be the tried and true 8DN!! Especially since its cheap and we all already have them lol
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Just saw a post on FB from sneak peak in new York. Said was still 8jp belt. No confirmation just going by what was posted.
Remember this is essentially a new sled and just like some of the Viper prototypes they aren't all the same. I heard that at least one still had the old clutches on it. They are Prototypes that's all.
smoothride
Boy the headlight looks the same and the windshield looks like it will bolt up. If the headlight does fit they better start the product line up they are going to need a lot of stock.
It will not work as a direct bolt on. The mounting locations are not the same and the plug is not interchangeable. Now you could make your own mounting and even make your own plug if you wish. Its has possibility.
fx-treme
- Jan 7, 2005
- 2014 SR VIPER LTX SE
Thank you, for the info and the pics. Much appreciated.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Yes talked to one the test riders and reps at show, he said it won't fit, it can be cobbed up but probably not worth the hassle for a poor fitting solution. Also asked about the single shot and he said yes absolutely it's a pos compared to the prototype. They said nothing changed but something has to be different. Mounting location by a bit changed, or angle of something etc, he wasn't sure what but something is different.
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
How did you obtain the photos?It will not work as a direct bolt on. The mounting locations are not the same and the plug is not interchangeable. Now you could make your own mounting and even make your own plug if you wish. Its has possibility.
View attachment 117629 View attachment 117631
From my connections at Yamaha.
