yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
The linkage without the shock change is changing the skid geometry from a falling rate to rising rate of resistance to further compression. This allows us to run softer pre load and resistance -smoother on small bumps with more resistance to bottoming. With my shocks I can only adjust preload with out rebuilding the shocks.This seems to make what you have to be similar to what comes on the 2016 LE with its float 3 Evols on the front and float evol and evol 3 in the skid. Is this a correct assumption?
Reaper
- Nov 10, 2005
- Starbuck, Manitoba
- 2014 SR Viper XTX. COTC, Hygear 141 pro link.
If you have a float on the rear... heck ya... this thing is amazing....I cant say enough good thing about it.
Mr. Sled, what did you wind up for pressure in the rear? Wondering if I need the 300 psi pump as well?
I think it was 200 to 225 lbs for my weight. I set it on the low end of my weight class setting.Mr. Sled, what did you wind up for pressure in the rear? Wondering if I need the 300 psi pump as well?
nherbst454
Any news about a getting a pre-season group buy from Hygear?
They ran a special in the spring, that was the last I heard of any deals from them.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
- 2015 Yamaha SR Viper X-TX
MrSled, was it the rear linkage and dual pressure that did the trick, or is the dual pressures for the front shocks also worth the upgrade?
Birkebeiner
Birkebeiner
Birkebeiner
The fronts help some but the rear linkage change and dual pressure was like night and day over stock. For me it's a must have.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
Another group buy / promo from Hygear on its way??
Birkebeiner
Birkebeiner
Birkebeiner
How many we have interested?
nherbst454
Me!
SaskAttack
- Jan 4, 2006
- Corning,SK.
- 17 Sidewinder XTX-SE
- Corning, SK. Canada
I am interested as well. One way or another this is one of those things I am just going to have to try myself.
birkebeiner
- Jul 27, 2009
- Norway
- Norway
I'm in
Birkebeiner
Birkebeiner
yamaha06
I'm in for the hygear dual pressure kit for the front fox floats.
We need a few more guys...
