cowwyy12
- Nov 29, 2014
- 2008 Yamaha Nytro 1000cc 4 Stroke
Hey new to the forums and servicing my own snowmobiles. I have a 2008 Yamaha nytro 1000cc 4 stroke. last year when it was very cold It would sometimes get a error code 12 but It would go away. I replaced the green 40A fuse/relay which I believe is for the ignition. same thing. this year I did an oil change, went to start it and it would just click I had the red low coolant temp. light on too. after attempting to start it a couple times the error code 12 came back and now its here to stay. Im wondering where I can start troubleshooting? I put my voltmeter across the starter underneath and tried starting it and I didn't get any voltage readings. Maybe an issue with the ignition before it gets to the starter? any ideas would be greatly appreciated thanks!
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
When you turn the key do you hear the fuel pump running. Also is your emergency stop button in the up position?
Pete
Pete
cowwyy12
- Nov 29, 2014
Pete[/QUOTE
Thanks for the reply. The kill switch is up in the right position. And yes the fuel pump does engage.
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2017 Sidewinder BTX Hurricane 270 tune
2015 Viper X-TX LE MPI turbo
herndonp
- Nov 28, 2012
- Freedom,NH
Code 12 is crank position sensor error. Try turning the engine clutch by hand ( with key off ) a couple of inches and try starting it again. Here is a link to Grizz's starter troubleshooting issues in the FAQ section at top of this forum. http://www.ty4stroke.com/threads/starter-system-troubleshooting.105358/#post-931403
cowwyy12
- Nov 29, 2014
Thanks this is helpful
